5100 Clip Adjusting
Discussion in 'Suspension' started by FARNORCAL, Feb 4, 2010.
  1. Feb 4, 2010 at 4:36 PM
    FARNORCAL
    FARNORCAL [OP] Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    how do i adjust my clips on my 5100's no really sure if theres a proper way of adjusting this clip or not.
  2. Feb 4, 2010 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Take it off, and move it to the slot you want it to be in. I have always done it with my fingers, but you can use pliers if needed.
  3. Feb 4, 2010 at 6:36 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I just used a c clip tool to spread it carefully as to not bend the clip.
  4. Feb 5, 2010 at 2:57 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Needle nose pliers is what i used.Take your time and work the clip out of the
    slot.Then slide it into the one you want.:thumbsup:
    Do not remove the c-clip from the shock body.
  5. Feb 5, 2010 at 4:10 PM
    FARNORCAL
    SEE BUILD
    Nice thanks for the tips guys.
  6. Feb 5, 2010 at 9:12 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    I just used my fingers as well. That way you will be more sure not to bend anything.
  7. Feb 5, 2010 at 9:19 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    one question..... is it a good idea to use 3" lift/spacer and bilstien 5100 with 1"lift? -so i will have 4" lift? will it work ok?
  8. Feb 6, 2010 at 1:26 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Doing so would max out,and then some,your cv's..uca's..you'll never get close to having a proper alignment. So..."good idea" NOT.
