5100, coils, and AAL thoughts
Discussion in 'Suspension' started by tacoman15, Oct 5, 2011.
  1. Oct 5, 2011 at 10:49 AM
    tacoman15
    tacoman15 [OP] Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Here is my 2 cents about these parts and how install went. I just recently installed 5100 and all four corners, eibachs, wheel spacers, and AAL. I took it to my dad's warehouse because my uncle has basically put in a pro garage in the back. He has a lift and air compressor which made install go much smoother. Everything was pretty straight forwards thanks to some awesome write-ups by other members! Wheel spacers were real easy to intall. We did run into a few problems though. When we were compressing the first eibach of the 5100, the spring compressor got stuck between the coils and we couldn't get it back out :eek:. There are a few more coils in the eibach coils than there are in the oem coils so if you are sticking with stick coils you should be alright. We ended up taking it to the local tire guy and they got the compressor out for us and put the other shock together as well. After all the parts were on, took it back to the local shop and had them put my new tires on and do a front end alignment. I noticed 5 miles down the road that the front right shock was acting funny so i pulled over and looked at it. The shock that the shop put together was shooting through the housing! No bueno. Took it back and told them that they didn't assemble the shock correctly and luckily I had the piece that they "missed". Thankfully they fixed it with no hassle and now everything works the way it should.
    Ride Quality:
    IMO, the ride has improved greatly! It a bit of a rougher ride (probably due to the eibachs) but I like that so it doesn't matter to me. I don't know how it has affected my gas yet, but as soon as I know ill give ya'll an update.
    Install:
    Really easy WITH THE RIGHT TOOLS! A buddy or two also makes a huge difference. If I ever do 5100's with eibachs again, I will probably have a shop put them together.
    Overall Thoughts:
    I would do it again in a heart beat. It has completely changed the way my truck looks and I love the way it drives now.
    Thanks for letting me rant lol I just wanted to share my thoughts with everyone and hopefully answer some questions for future reference :D
  2. Oct 5, 2011 at 10:56 AM
    loganlangley
    loganlangley Well-Known Member
    logan
    south alabama
    2011 trd sport 4x4
    Full JL Audio speaker swap with stealthbox, hid headlight and foglight conversion, weathertech floormats, UWS low profile black toolbox, 5100 billies with eibachs in the front and 5100 billies with 1.5 icon leaf pack in the rear.
    what kinda aal did you use?
  3. Oct 5, 2011 at 11:08 AM
    tacoman15
    Northeast Georgia
  4. Oct 5, 2011 at 11:11 AM
    loganlangley
    logan
    south alabama
    2011 trd sport 4x4
    ok cool. i ordered the same lift as you except i got the icon 1.5 leaf pac, i see you got the toytec 2 inch. i was wondering how mine was gonna look. still havent put my lift on yet. what size tires are you running?:mudding:
  5. Oct 5, 2011 at 11:12 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Same setup I run on my 1st gen. Good stuff!
  6. Oct 5, 2011 at 11:20 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Keep the overload in place with the Icon 3-leaf AAL and it'll look the same to the OP's. The Icon is a 1.5" AAL without the overload, keep the overload in place for an extra 1/2".
  7. Oct 5, 2011 at 11:29 AM
    loganlangley
    logan
    south alabama
    2011 trd sport 4x4
    hmm i think i might take mine out as to level the truck a little more and make my 5100s a little more friendly. what will i lose if i take it out?
  8. Oct 5, 2011 at 11:33 AM
    Pugga
    Massachusetts
    You'll lose the overload leaf and the extra 1/2" of lift. For normal day to day driving, the overload does nothing to affect the ride, it only helps out when you really load the truck up and the leaf pack squats enough so it's sitting on the overload leaf. Then the 1/2" thick overload becomes part of the active leaf pack so it won't squat any further. I kept mine on because when I do haul, it's usually pretty heavy however I've found that the 3-leaf AAL kit does a great job handling weight and I rarely hit the overload leaf.
  9. Oct 5, 2011 at 11:48 AM
    tacoman15
    Northeast Georgia
    im runnin 285/75/16 and they do scrub quite a bit but i was planning on cutting anyways its just a matter of finding time to do it
  10. Oct 5, 2011 at 11:49 AM
    tacoman15
    Northeast Georgia
    yeah man i love it!
  11. Oct 12, 2011 at 6:24 PM
    09YotaMan
    09YotaMan I love Tacos
    Edwin
    Chattanooga,Tn
    Barcelona Red Tacoma TRD
    i just ordered the billstien adjustable lift kit with 5100s. and a top plate since i got a double cab. the guy at toytec said i should get a full 3 inchs of lift. is that the kit you used
  12. Oct 12, 2011 at 6:29 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    I have the exact same setup, bilstein 5100's set at 0.85, eibach 1.8" springs, and 0.25" top plate spacer w/ the toytec aal. But I also have LR UCA's. A lot of the "scrubbing" you mentioned would be solved if you added some aftermarket wheels...I went with the ATX chambers.
  13. Oct 12, 2011 at 6:32 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Your truck looks kickass in the signature pic.....can't wait to get my lift & tires!
  14. Oct 12, 2011 at 7:50 PM
    tacoman15
    Northeast Georgia
    thanks man! it makes a huge difference!
  15. Oct 12, 2011 at 8:32 PM
    tacoman15
    Northeast Georgia
    I mean the eibachs have a few more coils in them than the OEM's. I think it is a bit rougher because I felt like i was driving around in a pillow but when i put all the parts on it felt like i was actually driving a truck which IMO is a great ride
  16. Oct 14, 2011 at 2:29 PM
    KingMoo
    KingMoo Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    I'm attempting the exact same setup this weekend. Although I haven't bought the AAL until I know which one will level it properly.
    You were able to set your 5100s at 0.85" with Eibachs and you didn't need to get new UCAs?
    I'm contemplating setting them at 0 to play it safe or 0.85" which would be much nicer...
  17. Oct 14, 2011 at 5:38 PM
    tacoman15
    Northeast Georgia
    no i haven't gotten new uca's but i plan on doing so in the near future
  18. Oct 14, 2011 at 5:54 PM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    I set mine at .85, and highly recommend it. I've been very happy with my setup
