5100/eibachs lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rraether, Mar 18, 2011.
  1. Mar 18, 2011 at 8:15 AM
    rraether
    rraether [OP] Well-Known Member
    Albuquerque
    07 tacoma 4x4 sport access cab
    debagged, windows tinted, custom NM trd sport decals, AEM bruteforce cold air intake, 13" wicked flow muffler, fox 2.5 DSC coilovers, all pro off road UCA's, fox 2.0 smoothies in rear with all pro off road expedition leaf springs, besttop softopper, first prototype of white clouds hybrid sliders!!
    So i am looking at installing the bilstein 5100 set at 0 and 1.6 eibach coils set up this next week on my 07 access cab and was wondering if i would need new UCAs with the bilsteins set at 0 instead of the .85 setting? any help would be great. Thanks.
  2. Mar 18, 2011 at 8:24 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I will soon be installing a similar set up 5100s and eibachs and drivers side spacer and Light Racing UCAs on a 2010 DC LB. Most everything I have heard is that a lift of 2.5 or greater will require the UCAs to bring the alignment into specs. For me, I'm likely going .85 to 1.75 and installing the UCAs as a precaution. I certainly am not an authority on this subject, just conveying what I have read. Hope it goes effortlessly and lets see pictures before and after.
  3. Mar 18, 2011 at 8:25 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Here's a picture of mine, Eibach's and 5100's at "0". No issue with getting it alligned at all, rides much smoother than stock on all kinds of surfaces. Highly recommended, also, I haven't heard of any problems with allignment setting the Billie's at .85.
  4. Mar 18, 2011 at 8:26 AM
    tacojpklx
    tacojpklx Well-Known Member
    eric
    michigan
    '10 AC OR, Magnetic Gray, 6spd
    toytec lift (eibach, bilstein 5100 at 0, Recall springs +Sumo Springs) seat covers, tint, weathertecs, shrokwork sliders, brute force rear bumper, in bed hi lift.
    I have those springs and shocks and set mine at 0. I have an AC as well. Stock uca here and the shop didn't mention any problems aligning it. It tracks fine with noticeably less body roll in corners. I'm pleased, cause i wasn't looking for mega lift - just a better drive and a touch more attitude up front. You'll be happy....
  5. Mar 18, 2011 at 8:31 AM
    rraether
    Albuquerque
    That makes me a lot less nervous. Thanks for the input.
  6. Mar 18, 2011 at 8:33 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You're correct, once you hit the 2.5" of lift you are in the area where you might need new UCA's (some get lucky and can still within spec, others not so much). At 3" it seems like you definitely need new UCA's.
    If you're getting Eibachs, don't put the 5100's past the .85 setting. The shocks aren't set up for that and you could end up causing some damage. There's too much down travel for the shock with that much pre-load on the coil.
  7. Mar 18, 2011 at 8:49 AM
    rraether
    Albuquerque
    That is what i thought. i want a lift on my truck for looks but i also want to keep the integrity of the truck. so thats why i am just going with this set up. i think it will be perfect for what i use my truck for.
