5100 fitment questions
Discussion in 'Suspension' started by Mike V., Mar 15, 2013.
  1. Mar 15, 2013 at 7:12 AM
    Mike V.
    Mike V. [OP] Member
    Georgia
    11 Prerunner, 13 Prerunner
    Ok, so I have (after reading 100's of threads) talked myself out of a "spacer" lift and am going with a 3" lift kit with Bilstein 5100 Height Adj. Coilovers
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    My question is I plan on running an 18" x 9" wheel, what offset/backspacing will i need and what is the largest tire size I can run with this setup? WIll I need UCA's?
    Oh, I have a dbl cap 2011 Prerunner...
  2. Mar 15, 2013 at 7:18 PM
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    You Will need UCA's anything over 2" of lift to get it aligned.
    As far as offset from what I have been told -12 offset with 4.5" backspacing will give you the best room for bigger tires.. I just got
    0 offset with 5" backspacing wheels and I am told I will be fine but I am only going max of 275's..
    Good luck.
