5100 in front with tsb aal in back question
Discussion in 'Suspension' started by Delrivpilot, Aug 29, 2010.
  1. Aug 29, 2010 at 5:10 PM
    Delrivpilot
    Delrivpilot [OP] Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    I currently have a toytec 2" spacer and the tsb aal on my rig. Was thinking of getting the 5100's and setting them at 2.5 to give a bit more lift in front. Has anyone done this and not done anything to the back end? Curious if truck is level enough and they are happy with set up. I searched the forum and couldnt find anyone who has done this. Thanks!
  2. Aug 29, 2010 at 6:49 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    I know almost nothing about this, so this is basically a *bump* for the pros.
    5100 set to anything more than 0 + 2inch spacer = damage to UCA's
    *I think that's what will happen*
  3. Aug 29, 2010 at 9:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you are talking about adding the billy's and keeping the spacer...that's not a good idea.
    If you are talking about ditching the spacer and adding the billy's, very good idea.
    I believe you will be slightly nose high with 2.5" up front with nothing on the rear.
  4. Aug 29, 2010 at 9:14 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    1.75" up front with 5100 and rear spring tsb will give you perfect level stance. take out the spacers.
  5. Aug 29, 2010 at 9:17 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    +1
  6. Aug 29, 2010 at 9:27 PM
    drifter
    Sam
    Oregon
    good stuff
    sweet. i was right. *gotta get some 5100's of my own*
  7. Aug 30, 2010 at 3:03 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Thanks All for input. Yeah, I would definitely ditch the spacer. If I wanted to go 2.5 in front, is a block in the rear the way to go? I don't want to mess with the springs if I dont have to.
  8. Aug 30, 2010 at 3:49 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    AAL out back............
  9. Aug 30, 2010 at 4:22 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Thanks T@co. Would the AAL I got with the TSB be sufficient?
  10. Aug 30, 2010 at 6:30 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Depends on whatcha do up front. There are 1.5 AAL & 2.0 AALs. My 5100s are on 2.5 & have the 3 leaf crap pack with 1.5" AAL and the truck sits level.(1.25 higher in back). I'd think if you have 4 leaf pack plus 1.5 AAL with 5100s set on 2.5, you have a bit more rake, higher in the back. 2" AAL would give a lot of rake if you have 4 leafs out back to start with.
  11. Aug 30, 2010 at 7:19 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    My 5100s are set @ 1.75 and with the stock 3 pack leafs in rear I was about 1/2 inch nose high. I installed a 1.5 aal from toytech and now once it settled its a perfect stance. Check my gallery for pics.
  12. Aug 30, 2010 at 7:55 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Thanks for all the input guys. So, if I have the TSB aal, that gives me 4. Then putting the 5100's on 2.5 should be close to leveling the truck. That sound right? I don't want any rake either way.
  13. Aug 30, 2010 at 7:58 AM
    Shack
    Shack Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    I have Billies @ 1.75 and the tsb aal. Sits completely level by look and actual measurement after settling.
  14. Aug 30, 2010 at 8:00 AM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    No. 1.75" up front with the rear spring TSB (3 leaf + 1 overload) will make you perfectly level. If you go 2.5" up front you'll need a 1.5" AAL on top of what you have in the rear.
  15. Aug 30, 2010 at 8:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Sounds like he has 3 leaf crap pack plus TSB AAL totaling 4 based on the description. If he has 4 leaf TSB oem springpack then that's different but he said AAL so that makes me think 3 leaf oem springpack + AAL to = 4. Which is it?
  16. Aug 30, 2010 at 10:06 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    THanks for your input T@co. I just have the 4 spring from the TSB. I think I am going to go ahead and pic up the 5100's and adjust accordingly. Will post pics when done.
  17. Aug 30, 2010 at 10:40 AM
    drifter
    Sam
    Oregon
    good stuff
    Question: would having the front end higher that the back end be bad? I know the back end lowers when you put stuff in the bed, but if the front end was always higher, no matter what, would it be bad?
  18. Aug 30, 2010 at 12:52 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    I'm not an expert, but I would say no. Esthetically I prefer to have it level
  19. Aug 30, 2010 at 1:31 PM
    drifter
    Sam
    Oregon
    good stuff
    Well, yea it would look weird to have the front higher than the back. I'm just making sure that it isn't bad for anything *like drive line*
  20. Aug 30, 2010 at 1:34 PM
    tacobox
    You'll have a bro lean with 2.5 and TSB or 1.5 aal. You'll have too much front rake if you do both TSB and 1.5 aal
    I'm goin to go with a 2" aal when I either go up to 2.5 setting or just go with 885 coils @ 0 setting
