5100 install help and ?'s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wickedwood, Jul 18, 2014.
  1. Jul 20, 2014 at 6:56 AM
    RileyLAFD
    RileyLAFD Well-Known Member
    Riley
    City of Angels
    '14 DCLB Magnetic Grey
    I guess I've got to start this very soon....
    Coils came preassembled
  2. Jul 21, 2014 at 7:12 AM
    lsutiger1
    lsutiger1 Well-Known Member
    Wilmington, NC
    2017 BLACK TRD OFF ROAD DCSB
    3inch lift,285/75/16 on method 301's
    Don't know! Let us know what you find!
  3. Jul 21, 2014 at 7:13 AM
    RileyLAFD
    Riley
    City of Angels
    I made sure I purchased them preassembled so I wouldn't have to deal with them. But after install I had no alignment issues!!!!
  4. Jul 23, 2014 at 6:09 PM
    MrSmith253
    MrSmith253 Well-Known Member
    Cameron
    Fife, WA
    2010 supercharged 4x4 trd sport
    anyone know where i can see install pics or videos ive had my 5100s for like 6 months just haven't installed then cause i thought you needed a spring compressor but it sounds like you dont
  5. Jul 23, 2014 at 6:25 PM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    what are you going to set the 5100 at
  6. Jul 23, 2014 at 7:03 PM
    lsutiger1
    Wilmington, NC
    Had any luck?
  7. Jul 23, 2014 at 7:05 PM
    RileyLAFD
    Riley
    City of Angels
    Noise still there when I start out and then goes away. Made sure everything was nice and tight after a 300 mile trip. Nothing moved or was loose. Ride is beautiful. I just need to add the AAL. Oh yeah and I had no drift without doing an alignment, my plan is to do an alignment after I figure out how to install the AAL.
  8. Jul 23, 2014 at 7:07 PM
    MrSmith253
    Cameron
    Fife, WA
    2.5 front and 1.5 aal in the rear
  9. Jul 23, 2014 at 7:09 PM
    MrSmith253
    Cameron
    Fife, WA
  10. Jul 23, 2014 at 7:15 PM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    It's a bad idea. It's dangerous as hell. Not to mention it's easy to damage a shock shaft or top plate doing it in the truck. Doing it the right way is no big deal. Call around your local shops, I'm sure some one will change your coils over for a very small fee. All you need to do is remove the strut assemblies and take them to them. If your wanting to set them at 2.5 you may not even be able to compress them far enough.
  11. Jul 23, 2014 at 7:17 PM
    MrSmith253
    Cameron
    Fife, WA
    here you go aal install
    http://www.tacomaworld.com/forum/suspension/31118-how-install-add-leaf-w-pics.html
  12. Jul 23, 2014 at 7:39 PM
    MrSmith253
    Cameron
    Fife, WA
    anyone know how to adjust that silver clip thing to adjust the height on the shock???
  13. Jul 23, 2014 at 7:43 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Seriously, No this operation isn't dangerous if you are careful. The upper control arm wraps around the strut. The spring just can't fly out. The jack under the lower control arm method releases the pressure (or compresses)!nice and controlled. Safer than most DIY compressors and works about the same as a pro hydraulic compressor. Just be smart. If you can find some local members and have a mod day to help you out.
  14. Jul 23, 2014 at 8:08 PM
    MrSmith253
    Cameron
    Fife, WA
    yea thats what i thought seems like its more controlled this way
  15. Jul 23, 2014 at 8:12 PM
    #35
    Dragons Taco
    Derek
    Cary/Raleigh NC
    It really is. If you ever have used those clamps before and you try this jack method you will be like "holy shit, how come this gets such a bad rap?" People can do stupid things. There is a video going around of an ass who un bolts a strut while holding to the shop floor with his foot. Now that is dangerous. This barely needs to compress before you can get your nut back on the strut. Boom safe. Tighten her up.
  16. Jul 23, 2014 at 8:16 PM
    #36
    MrSmith253
    Cameron
    Fife, WA
    even if you are going 2.5 in
  17. Jul 23, 2014 at 8:45 PM
    #37
    Dragons Taco
    Derek
    Cary/Raleigh NC
    You don't have to fully compress. Just enough to get the strut bolt in the hole and get your nut threaded on. Then jack it up, tighten and torque everything. The hardest part is you are using a wrench on the top bolt, can't fit a ratchet above the tower.
  18. Jul 23, 2014 at 8:46 PM
    #38
    Dragons Taco
    Derek
    Cary/Raleigh NC
    One more thing. Make sure your spring is right side up. Flat side up, side with the full wire showing needs to seat in the shock ring.
  19. Jul 23, 2014 at 8:53 PM
    #39
    MrSmith253
    Cameron
    Fife, WA
    do you know how to adjust the clip on the shock for your height adjustment i cant get it off
  20. Jul 23, 2014 at 8:55 PM
    #40
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I second this. Don't be stupid and you will be fine.
