5100 install issue - dust boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Jul 31, 2016.
  1. Jul 31, 2016 at 4:41 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I hear ya just figured I would post it for you
    Pigpen[QUOTED][OP] likes this.
  2. Jul 31, 2016 at 4:48 PM
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    Back on topic...
    I'm sure the washer in question keeps the lower bushing in place and doing its job (when installed correctly). The lower bushing is currently being abused, which would explain the appearance of the upper bushing.
  3. Jul 31, 2016 at 6:39 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Ouch that sucks! Hope you've got access to a spring compressor? Short of that its not too much work I guess?? Just sucks doing the same job 2x
  4. Jul 31, 2016 at 6:43 PM
    Pigpen
    Dan
    Northwest Montana
    Yeah, I bought one the last time I did the job. It's the 3rd set I've done and I figured it won't be the last.
  5. Jul 31, 2016 at 6:52 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Pretty sure the washer that's supposed to be under the top hat not being where it should have been, (on top dust boot) allowed shaft to go into the top hat more than it should as the suspension was working, causing the dust boot to get pushed down. That probably is the squeak you heard.
    That's also likely the reason the top bushing isn't squashed. Without that washer, as you tighten, it would just clamp down against the bottom of the top hat more. Which would push against the dust boot.
  6. Jul 31, 2016 at 6:54 PM
    Pigpen
    Dan
    Northwest Montana
    I'm hoping I can reverse the damage.
  7. Jul 31, 2016 at 6:57 PM
    Fitz235
    Rob
    New Hampshire
    I think you may find you need new top hats. I would think the shocks would be alright, minus the dust boots.
  8. Jul 31, 2016 at 7:03 PM
    Pigpen
    Dan
    Northwest Montana
    They are new top hats. They've only been in for about a week
  9. Jul 31, 2016 at 7:10 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Hopefully the holes for the shafts to slide through aren't rounded out from excess movement
  10. Jul 31, 2016 at 7:49 PM
    hollandhunter
    hollandhunter Well-Known Member
    2015 Tacoma DCSB sr5 4x4
    Good info here. OP this would be a great excuse to yourself or better half to upgrade to a 2.5 fully adjustable coilover. Just saying. Ha
  11. Jul 31, 2016 at 8:46 PM
    Pigpen
    Dan
    Northwest Montana
    These are brand new top plates, 885s and 5100s. I'm done with upgrades for awhile. Every mod this summer has been a struggle.
  12. Aug 1, 2016 at 2:02 AM
    Fitz235
    Rob
    New Hampshire
    Check them out when you get stuff apart. I'm just thinking as pudge151 said, the holes going through the top hat for the shaft, may be jacked (at least on the bottom side), from the part of the shaft that holds the dust boot up, riding up inside the integrated bushing that's in the top hats. In either case, the top hats are cheap enough to replace, if need be.
    Also having a tough time looking that shirt, that thing is nasty.
  13. Aug 8, 2016 at 5:10 AM
    clickws
    clickws Well-Known Member
    South Carolina
    1999 Toyota Tacoma Xtra Cab 4x4 2.7L 5-Speed All Manual
    Stock Alloys w/ 31.5x10.5x15 (Previously Black Pacers w/ BFG KM2 32xx11.5)
    Update?
  14. Aug 8, 2016 at 7:20 AM
    Pigpen
    Dan
    Northwest Montana
    I got in and reassembled the 5100s with everything in the correct order. The top hats had some minor wallowing from the rod, but not enough to concern me. The truck rides as it should now.
    When I upgrade to better coilovers, I'll part these out and toss the top hats in the trash.
    jtweezy likes this.
  15. Aug 8, 2016 at 7:32 AM
    #35
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Rode OMEs for 8ish months, including my trip to NM, had a set of Fox 2.5 RR DSCs and TC UCAs waiting for me when I got back. Done. Not looking back.
  16. Aug 8, 2016 at 7:50 AM
    #36
    Pigpen
    Dan
    Northwest Montana
    I've never run OME struts, but the 5100s work pretty well for my current uses. I'm done spending money on the truck for this year. Mostly :rofl:
    3coma likes this.
  17. Aug 8, 2016 at 11:46 AM
    #37
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Same here. I have a plan to keep my word, though. If I spend any more money on the truck, I won't have any money for the wedding and the fiancee will murder me, thus making it my last year with the truck.
  18. Aug 8, 2016 at 11:56 AM
    #38
    Pigpen
    Dan
    Northwest Montana
    I'm in the middle of a river raft build, my mountain bike needs work, my work trailer needs axle seals, I need to buy a split board before winter, and hunting season is just around the corner. And I'm in the middle of moving.
    I also convinced one of our more inventive members to reinvent the wheel, so to speak... That's where I will end up spending a little more on the truck this year. That's a top secret project, though - until it's ready to sell.
