5100 install issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PSJ, Oct 7, 2009.
  1. Oct 7, 2009 at 5:43 PM
    PSJ
    PSJ [OP] Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    It seems many like to go with the highest setting, or the 2.5 inch. But I have read many who say they have issues with a vibration at this setting. Some complain about alignment issues with this height. Then there is the argument putting the stock suspension components in this position results in future failure of front end components.
    My question is, for those who went with the 1.75 setting, are you having any issues like the ones mentioned above, or anything else? Please give feedback if you can with the 1.75" setting. Thanks
  2. Oct 7, 2009 at 5:49 PM
    mhann
    mhann Senior member
    I went with 1.75 setting and 17" wheels with no problems
  3. Oct 7, 2009 at 5:51 PM
    PSJ
    Sebastian Inlet
    Stock Sport model or aftermarket wheels?
  4. Oct 7, 2009 at 7:22 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i went 2.5", no problems at all. alignment is slightly off, but uneven tire wear is not bad at all after 35k.
  5. Oct 7, 2009 at 9:11 PM
    M2M
    M2M Well-Known Member
    bilstiens, sport 08 w/o scoop, debadged
    nanda with the 1.75 - stock sport wheels - 49 k on the crappy tires that came with it -
    have a new set of nittos in the garage, ready to go for snow season !!
  6. Oct 8, 2009 at 6:53 PM
    PSJ
    Sebastian Inlet
    Any other guys out there running the 5100's @ 1.75" up front with positive or negative feedback with this set up?
  7. Oct 8, 2009 at 7:04 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    1.75 for me, rear tsb, 16" OR wheels and stock rugged fails. Great ride tracks perfect. Do it, I skipped 2.5 for the exact same reason you are thinking because of the vibes chance. I didn't want to chase a fix for the vibes, this is my daily driver. The 1.75 is almost level as well....just a slight rake, but my driveway goes uphill a little and looks mean out there!
  8. Oct 8, 2009 at 7:25 PM
    PSJ
    Sebastian Inlet
    That is what I thought. I have the same set up, except dunlop snails. DD concerns is with me as well with this truck. After my TSB rear being done, I have a 2.5"+/- difference front to rear height at stock height.
  9. Oct 8, 2009 at 7:46 PM
    PSJ
    Sebastian Inlet
    I think the Prerunner 4 cyl being lighter will draw a tad more overall height with the 5100's due to engine/trans weight differences.
  10. Oct 9, 2009 at 12:10 PM
    DorsoDoug
    DorsoDoug Active Member
    Doug
    Greater Pittsburg, PA (Ohio River Valley)
    '08 AC SR5, 2.7L, 4 x 4, Black Sand Pearl
    Rear TSB, 1.75" 5100s, 265/70/16 TRD BFGs, Anthracite FJ TRD wheels Toyota Seat Covers, Killer Toyotal All-Weather Mats, Black Window Tint
    I had the TSB done three weeks ago, 4 leaf spring pack and F & B TRD shocks . The rear suspension not only raised the back, but the spring/shock combination increased the firmness of the ride on all four corners. Not a problem at all, except I felt like I was going down a hill all the time because of the front biased rake. I waited a week or so for the suspension to settle in and had the 5100s installed at 1.75". The truck is nearly level with a slight front bias, and the ride is firm, but not uncomfortable. Initially, I could almost imagine some wandering on the highway, or a sensation that the truck was light in the front, but I don't seem to notice it now. I agree with something posted previously - this is the stance our trucks should come with from the factory. I've owned three other Toyota 4 x 4s over the last 20+ years, and this set-up emulates that of previous trucks. It rides and handles like I think a truck should, not like a "gentlemen's truck".
  11. Oct 9, 2009 at 5:32 PM
    PSJ
    Sebastian Inlet
    Exactly the same set up as I had planned. Your truck looks good, I guess our trucks will look alike minus the color and tires for now when I get the 5100's installed. Thanks for the info and photo :cool:
  12. Oct 9, 2009 at 8:25 PM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I set mine at 1.75 and have no problems and love the ride. Levels it out nice, I also had the TSB done. Its the best setup Ive ever had on a truck.
  13. Oct 9, 2009 at 9:04 PM
    rightspy
    rightspy Junior Modder
    Fr & R plate bumpers, AR Mojave, Bilstein 5100 & Magnaflow SS CB
    I went with 1.75, rear TSB only (no lift). The ride is awesome. Before 5100 the rear TSB made the front feel soft comparatively. Now with the 5100 the balance is back front/rear. Extremely happy with this setup.
  14. Oct 10, 2009 at 4:47 AM
    PSJ
    Sebastian Inlet
    Sounds like the 1.75" is the way to go. Always thought I would only go to the 1.75" setting, but with the 5100's sitting in the garage waiting for me to get the TSB done, I started second guessing myself. I know the rear springs will settle, but I am around 2.5" higher in the rear then the front post TSB.
  15. Oct 10, 2009 at 5:46 PM
    PSJ
    Sebastian Inlet
    No other 1.75" guys out there? Give feedback if you can...
    Thanks
  16. Oct 10, 2009 at 6:33 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    I have the 2.5 setting on my 06 reg cab and 2" aal in rear and I am running with 1\4 spacers behind front wheels 285\75\16's and was able to hit alinement, I do rub uca if cranked all the way, I just know where to stop turning or go all the way and back off a lttle before take off,the chances of cranking all the way going down the road is never going to happen.. the ride is very good at this setting. And truck sets factory.
    Does anyone know if the spidertrax spacers are cool to run or will they cause tires to hit inner fenders, and do they make the wheels stick way out past fenders? thinking about going that route..
    Thanks..
  17. Oct 10, 2009 at 7:37 PM
    jwhelan
    jwhelan Well-Known Member
    JW
    Dallas Texas
    05 TRD Silver
    TRD PreRunner, 5100's on all four fronts @ 1.75, AAL, SP performance rotors, hawk pads, 17" FJ Cruiser wheels P/C black, 265/65/17 BFGR Rugged Trails, BHLM , painted grill, blacked out emblems
    ok, I'm getting an education here..what is TSB?
  18. Oct 10, 2009 at 9:21 PM
    rightspy
    couple things you have to keep in mind. Rear springs will settle to about 2" post TSB. Also, the rear wheel well is a bit higher than the front giving you a feel of a higher rear. The 1.75 w/TSB will look nearly perfect. It'll kinda still look like it's higher in the back because of the wheel well.
  19. Oct 11, 2009 at 5:36 AM
    PSJ
    Sebastian Inlet
    Thats what i have heard- the rear will settle
  20. Oct 11, 2009 at 5:50 AM
    PSJ
    Sebastian Inlet
    Techinical Service Bulletin - certain issues, which are not recalls, that some owners have with their vehicles. In this case, Tacomas have had a 3 leaf pack which created harsh rides, bottoming out, etc. when carrying weight in the bed, and for those who experienced these issues Toyota has offered a frimer, 4 leaf pack, plus shocks on some models to help correct this issue, no charge under warranty. Current vehicles covered, 05-08 4x4/Prerunner models. However, like myself, many with 09's have had the rear TSB done, but the TSB should be updated to include the 09's soon. ;)
