5100 install light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by txfisherman76, Apr 12, 2012.
  1. Apr 12, 2012 at 8:35 PM
    txfisherman76
    txfisherman76 [OP] Member
    Bret
    Pearland
    09 TRD sport DCLB
    bilstein 5100s set at 2.5, in channel vent visors, and black weathertechs
    ok sorry if this is a repost but I searched and didnt find anything. but I installed the front bilstein 5100 on my truck today. Everything drives fine except for the allignment which is gonna be done tomorrow. my truck is throwing up a light, i attached a picture of it. the light dosent come on a soon as i start the truck i have to drive it like half a mile and it comes on. the book says that it has something to do with the traction control and i checked each sensor on each side and they are fine. im just wondering if it has something to do with the alignment being off so bad or if one of my sensors messed up while instaling the shocks. i also installed the shocks by dropping the control arm like in one of the videos on here, if that helps at all.
  2. Apr 12, 2012 at 8:38 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Check all of your abs wires. Did you let the wires support the calipers? What did you set thr billys at?
  3. Apr 12, 2012 at 8:39 PM
    RedDragonTaco
    RedDragonTaco Knight Industies Toyota Tacoma
    Slc, UT
    2007 Double Cab TRD Sport
    Toytec 3" Ultimate w/ LR UCA's, 18" Rockstar rims, Nitto Grappler 285/65/18, OEM roof rack, foglight anytime mod, front bull bar and Smitty side steps, tonneau cover, debadged, BHLM, blacked out tail lights, stubby antenna, flowmaster
    This is good to know for when i do my lift
  4. Apr 12, 2012 at 8:40 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    it might go away when it is aligned
  5. Apr 12, 2012 at 8:44 PM
    txfisherman76
    Bret
    Pearland
    09 TRD sport DCLB
    i set them at 2.5 and i just checked where it connected to caliber didnt really follow the wires as high as i could see them, and the wires supported the calipers as soon as i disconnected it but then moved it so the wires werent supporting the calipers.
  6. Apr 12, 2012 at 10:27 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    What kind of coils?
  7. Apr 13, 2012 at 6:25 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    The wires to the ABS sensor are tiny and easily broken. I did it when I installed 5100s in my previous Tacoma. I ended up having to build my own ABS sensor wire by splicing the ends on and running new wire.
  8. Apr 13, 2012 at 6:48 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Vehicle stability control (VSC) Calibration
  9. Apr 13, 2012 at 9:14 AM
    60guy
    60guy BADASS
    Dustin
    Maryland
    2017 Limited Double Cab
    What PSU taco85 said. I did the same thing, and it was around $125 to get it fixed at the dealer...
  10. Apr 15, 2012 at 12:03 AM
    txfisherman76
    Bret
    Pearland
    09 TRD sport DCLB
    ok so I took the truck to get it alligned and the light went off so im guessing that the light was beause of the allignment.
  11. Apr 15, 2012 at 8:28 AM
    TrdSurgie
    TrdSurgie revised
    SoCal
  12. Apr 15, 2012 at 8:57 AM
    anthony250f
    Anthony
    San Diego, CA
    :yay:
  13. Apr 15, 2012 at 5:58 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    No. It was because of the VSC. There isn;t a sensor for alignment, that would be too simple.
  14. Apr 15, 2012 at 10:46 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The alignment was the cure. The VSC sytem has a steering angle sensor on the column, and if the steering wheel is not straight when the truck drives straight due to misalignment, the VSC will log a fault code and turn the light on.
  15. May 22, 2013 at 12:57 PM
    pghpete
    pghpete Member
    Pete
    Pittsburgh
    trdsurgie did you paint your 885's red or did you buy them that way? they look sick red
  16. May 22, 2013 at 1:03 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Paintd them red. Thanks.
  17. May 22, 2013 at 1:03 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    ^ guessing they came that way Toytec maybe?? Wrong :(
