5100 install....oops
Discussion in 'Suspension' started by ryanringle, Jul 24, 2010.
  1. Jul 24, 2010 at 7:35 PM
    ryanringle
    ryanringle [OP] Active Member
    Chandler, AZ
    08 TRD 4x4
    Debadged Tinted Tails Moto Metal 951 265/75/16 Hankook dynapro atm
    Just got my truck back from the alignment shop, and they were able to align everything, with a caster of 2.0, and 1.8, are these going to be high enough? Also, when I looked at the coil springs, i noticed that the end of the coil spring on the bottom is facing the front, I think it was suppossed to face the rear of the truck, Do I need to take them off and adjust this, or does it not matter?
  2. Jul 24, 2010 at 7:53 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    Caster should be high enough.
    If it isn't the truck will wander at highway speeds.
  3. Jul 24, 2010 at 9:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Pics would help us.
  4. Jul 25, 2010 at 11:36 AM
    ryanringle
    Chandler, AZ
    08 TRD 4x4
    Here is a pic of the coil with the 5100 installed. Notice how the end of the coil is facing towards the front. Is this bad?
  5. Jul 25, 2010 at 11:46 AM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    You need to fix that asap!!!!!
    JK, let it ride. As long as it's seated correctly, which it looks to be, your good!
  6. Jul 25, 2010 at 11:49 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Nah your fine... As stated as long as the coil is seated correctly you'll be fine.. I believe mine are facing in towards the front/center of my truck.
  7. Jul 25, 2010 at 1:10 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    Acorrding to the pic Rianringle took , Mine is not facing in toward , they ( both side ) facing to the rear of the truck but they sat correctly . Are they safe ? or Should I have to take them off and adjust them ?
  8. Jul 25, 2010 at 9:15 PM
    Lentsnh
    It really doesnt matter which way the end of the coil is pointing, as long as they are seated correctly on the coil seat your fine.
