5100 install question
Discussion in 'Suspension' started by oaker, Jul 7, 2012.
  1. Jul 7, 2012 at 4:25 PM
    oaker
    oaker [OP] Active Member
    '11 Tacoma DCSB TRD
    so im hopin to install the billy 5100s soon..........my question is: is it possible to install them by only removing the sway bar and tie rod end?....i really dont want to remove the lower ball joint bolts. thanks for any input.
  2. Jul 7, 2012 at 4:59 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Depending on what method you are using to install them.
    I use this method and you are required to remove the sway bar, and remove the lower ball joint bolts but not the tie rod end.
    No matter what method you use you will have to get it aligned afterwards.
  3. Jul 7, 2012 at 5:06 PM
    Holyfather
    Holyfather Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
  4. Jul 8, 2012 at 4:33 AM
    oaker
    '11 Tacoma DCSB TRD
    im gonna have a shop switch the springs for me, i was just wondering if they could be reinstalled without removing the lower ball joint bolts, cause i guess the 5100s are a little longer.
  5. Jul 8, 2012 at 10:43 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Defroster mod, Bilstein 5100s front, Adjustable Ranchos rear.
    I used that video method and did not have to remove the sway bar. I have read where some people said they did have to. Why is that?
  6. Jul 8, 2012 at 12:55 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The 5100s are the exactly same length as stock shocks.
  7. Jul 8, 2012 at 1:00 PM
    white toy taco
    white toy taco 505 Member
    Gian
    Albuquerque, NM
    02 4X4 Taco SR5 TRD V6
    All-Pro tube bumper, 5100's at middle setting w/OME 881's, rebuilt leafs w/ 2 chevy leafs, 265/75/16 Km2's, CloudyFab sliders, 6000k HID headlights (35w), 16" LED light bar,100w KC Daylighters,
    even the adjustable ones?
  8. Jul 8, 2012 at 1:01 PM
    KPT
    09 Prerunner
    Correct, they have the same extended length as stock shocks. They achieve lift by moving the spring perch up, which in turn decreases the available down travel.
  9. Jul 9, 2012 at 4:23 AM
    oaker
    '11 Tacoma DCSB TRD
    so even set at 1.75 theyll be the same length?.....ive seen some saying theyre a 1/2" or so longer and you need to pry the LCA down a little to squeeze them in.....im just hoping to not disconnect the LCA
  10. Jul 9, 2012 at 7:35 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Can I ask why you don't want to remove the lower ball joint bolts to do it? They are really easy to reinstall. I've done it before by seperating the upper ball joint from the upper control arm and then found the video for the easy install method. I've done it this way twice now and I will never go back to separating the upper ball joint.
  11. Jul 9, 2012 at 8:04 AM
    oaker
    '11 Tacoma DCSB TRD
    actually im hoping i dont hafta remove the upper or lower, id like to keep the disassembly to a min and only remove the sway bar if possible.
  12. Jul 9, 2012 at 9:26 AM
    Bama_TACO
    Winfield, AL
    You will have to do one or the other. You won't be able to get the stock spring/strut assembly out without loosening the lower or upper ball joint. Again. The bottom is easy. 2 bolts and you are done. No hammering and no fork to get it apart.
    I use the easy install method and I don't loosen the sway bar or the alignment bolts. I just pry down on the lower control arm once I have the lower ball joint loose. I put my 5100s with OME 885s in using this method without any problems.
  13. Jul 9, 2012 at 10:06 AM
    DDD
    Derek
    Santa Clarita, CA
    I guess I should clarify. I made this video and have used this method about 3 or 4 times. I have had my sway bar removed before I every attempted this method and when making the video I never mentioned the sway bar because I forgot all about it. Some other members have mentioned to me that they had to disconnect their sway bar when using this method. I have been meaning to add that note to the video.
    I agree with this.
  14. Jul 10, 2012 at 7:57 AM
    BTO
    California
    This sounds like the best of all. I guess you use a long pry bar to get the LCA down?
  15. Jul 10, 2012 at 8:42 AM
    Bama_TACO
    Winfield, AL
    The prybar I use is about 18". It has a point at the end that I can put in one of the holes in the lower control arm and push down.
  16. Jul 10, 2012 at 9:08 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Yes, it does not matter what setting they are set to, they have the same extended length as the stock shocks.
    I only disconnected the sway bar and the tie rod end when I installed my 5100's and Eibachs. I didn't touch the lower or upper control arm ball joints.
    This is the thread I used as a guide:
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
