5100 Install
Discussion in 'Suspension' started by tomonian77, Mar 29, 2010.
  1. Mar 29, 2010 at 11:26 AM
    tomonian77
    tomonian77 [OP] Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    After calling around and getting estimates from $300 to $500 to install front end billies I have decided to try and do it myself. Auto Zone will rent me a coil spring compressor for $33 so I am going to give it a shot. Anything I should look out for?
  2. Mar 29, 2010 at 11:35 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Good luck bro... Hope it goes well
  3. Mar 29, 2010 at 11:38 AM
    JackedTaco
    JackedTaco Well-Known Member
    Johnny
    USA, Earth...
    07 Access Cab TRD Off Road
    Weathertech Mats, Thule rack custom install on bed caps. Foglite anytime mod. K&N air filter. Rear leaf TSB. Tinted passenger windows. TRD CAt Back exhaust. Bilstein 5100 front shocks at 1.75".
  4. Mar 29, 2010 at 11:40 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    it's easy
  5. Mar 29, 2010 at 11:41 AM
    tomonian77
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    As far as I can tell from looking at all the write ups the hardest thing is the compression. If it works out well I will probably set a meet up for all the other locals that need them installed.
  6. Mar 29, 2010 at 11:44 AM
    DLR07
    DLR07 Well-Known Member
    David
    Tampa
    pretty much stock, very minor upgrades plus tires
    Hey man keeping looking around, I got all four of them installed for $110.
  7. Mar 29, 2010 at 11:46 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    it should take you about 30 minutes to change these....that is once you get the hang of the spring compressor.
  8. Mar 29, 2010 at 11:53 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    A word of advice, when reassembling the struts make sure you get the alignment of the top plate where it should be. It will make things go a lot smoother when putting the shocks back in. The whole job should only take about an hour or so if you have the right tools. An impact wrench will make things a breeze when it comes time to compress the springs too. Just hit each side a little, until you've compressed the spring far enough for removal/reassembly.
  9. Mar 29, 2010 at 11:56 AM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    It's pretty easy if you don't get distracted, or strip a nut....*lol*. I took my struts to NTB to get them swapped, Took an hour and $40. Our spring comp. was to small to work with. Just pay attn. and you will get it done and save some $$
  10. Mar 29, 2010 at 12:01 PM
    tomonian77
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    So you jacked up your truck and took the old ones off then went to NTB and had them set up the new billies?
  11. Mar 29, 2010 at 12:03 PM
    blackwatertaco
    Jay
    Alvin/Pasadena, Tx
    Yup, Easy. As they were putting the 5100's on I was installing the rear shocks, which BTW was the harder part of the job. I wound out just sawzawing my rear shocks off.
  12. Mar 29, 2010 at 12:05 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    You should set up a meet so you can get some people to help you out.
  13. Mar 29, 2010 at 12:32 PM
    SC4333
    Grant
    San Antonio, TX
    I like your style! I've done the same in a couple instances where the rust wasn't even worth dealing with. The Sawzall never fails!
  14. Mar 29, 2010 at 12:35 PM
    blackwatertaco
    Jay
    Alvin/Pasadena, Tx
    It made sense...If they are junk anyways just destroy them...LOL don't fight with it if it's gonna just go into the trash.
  15. Mar 29, 2010 at 12:46 PM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    My rear 5100s should be in today. I hope my install goes better than yours did.
  16. Mar 29, 2010 at 12:56 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I've done it 3 times. PM me if you have problems.
  17. Mar 29, 2010 at 1:43 PM
    tomonian77
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Taking the wee wee route, found a shop that would do the install and alignment for $210.
  18. Mar 29, 2010 at 1:49 PM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    This is something Doug (4WD) pointed out that is very important...
