5100 leveling problem
Discussion in 'Suspension' started by chestnut35, Dec 27, 2009.
  1. Dec 27, 2009 at 8:54 AM
    chestnut35
    chestnut35 [OP] Well-Known Member
    tempe
    08 Off Road Double
    bixenon HID, chrome running boards, access tonneau cover, Bilstein 5100, rear TSB leafs, 18x9 XD wheels, 285/60/18 Nitto Terra Grapplers, Front Bull Bar
    I have the 5100 set up front and rears w fabtech AAl's in the back but the front seems to sit lower,any recommendations. Also,I'm thinking of switching to something that gives me a full 3" as opposed to the 2.5 that the 5100's give me, what do most people recommend or have as there set ups? Thanks ahead of time guys
  2. Dec 27, 2009 at 8:55 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Do you have a Pre-Runner, or 4x4?
  3. Dec 28, 2009 at 2:38 AM
    chestnut35
    tempe
    08 Off Road Double
    prerunner. trd off road
  4. Dec 28, 2009 at 3:10 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    u can get some 3" OME springs and set the 5100's back to 0 or get OME shocks and springs
  5. Dec 28, 2009 at 3:59 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    What is 3" gonna get vs. 2.5? Not a thing. If you have them set on 2.5 up front then just get a 1.5 AAL instead of the 2 or 3" you have. With the front set on 2.5 with TRD springs & 1.5 AAL on 3 leaf pack it'll be 1.5 higher in the back. It looks dead level. If you have 4 leaf pack then you might not even need the AAL. Have you tried it like that? What were the measurements to top of fr & rr wheel well arches thru center of wheel? You're gonna need UCAs to get caster right where truck doesn't wander also. Here's a pic of mine with 2.5 up front & 1.5 AAL on 3 leaf crap pack out back.
    fr wheel well arch = 38" & rr wheel well arch = 39.5"
  6. Dec 28, 2009 at 5:23 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    that was a little confusing but i understand what youre saying lol. i agree, 1.5 aal and 2.5 billys up front
  7. Dec 29, 2009 at 4:08 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    How much lift is your aal 1.5? trd trucks dont have that much rake when there stock maybe 1.75in lower in the front. its hard to get it dead level with a 2.5 front lift. ur probably only looking at .75 in of rake. not that bad really. i prefer the slightly raked look compared to level. try the ome springs with the spacers and ur billy's set at stock height. that'll give u 3inches up front. and with ur 1.5in aal you should be farely level if not very slightly raked?
  8. Dec 29, 2009 at 11:30 PM
    chestnut35
    tempe
    08 Off Road Double
    I guess it wasnt so much the 2.5 versus the 3 so much as i just wanted to level it out. I may go the ome spring route that most people talk about or possibly just go coilovers if i can find a smoking deal. I have the bilstein 5100 setup right now just not sure if i should upgrade to coilovers or just go w the springs. And yes i do have UCAs already installed
  9. Dec 30, 2009 at 3:31 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    AAL is 1.5, it's in my previous post. Before lift, fr wheel well arch = 35.75" & rr wheel well arch = 38" which equals 2.25" of rake stock on base model prerunner access cab with 285/60/18s. After lift, fr wheel well arch = 38" & rr wheel well arch = 39.5" with same wheel/tires. Sure, it's a preference thing. 2.5 vs. 3 will get you microscopic amount more tire clearance & higher center of gravity - good & bad. Which is what you get with whatever you do with it. Measure what you have now, compare it to what you want to end up with & go buy the parts that'll get ya there. All there is to it. Have fun....
  10. Dec 30, 2009 at 8:37 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I wouldn't put the 5100 to 2.5, it will make for a harsh ride and you won't be happy.
    I just put some OME 886 on (I have the All Pro Bumper) that I got for Christmas (Thanks Mom and Dad) and put my 5100s at 0 and the ride is SOOO much better than when they were at 1.75 with the TRD springs. I was at 36 inches to the bottom of my fender before and now I'm at 38.5" so overall from STOCK (not the lift before) I'm at about 3" of lift. I will be taking pics soon as I can and posting them in my build thread. But if you want 3" you won't be happy with anything else so do what you want to do.
    The only thing is I had to have a shop put the springs on the shocks, because the Autozone compressor wouldn't come off the springs when I decompressed them. It was only $50 and took them about 20 minuets so not that big of a deal, just make sure you have another vehicle available to get it them down there.
  11. Dec 30, 2009 at 10:44 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You might not be happy @ 2.5 if you spend most of your time in moderate to hardcore offroad situations but the ride is nowhere near harsh if mostly road to light offroad with occasional harder offroad. Mine rides better than my car does on frwy & tons better than the car would off anything but smooth fresh cement. Depends on the focus of your intended use. I would NOT race offroad with this setup or anything beyond light to moderate shit on occasion that a prerunner would handle anyway. 4X4 = different story. OP says he's got prerunner, speaking to that.
  12. Dec 30, 2009 at 11:02 AM
    rclangelan
    rclangelan Well-Known Member
    Sykesville, MD
    2012 DblCb Baja Ed. (Black)
    TRD Front Skid Plate, Tacoma All-Weather Mats, BFG AT KOs (265/70/16)
    What is the diameter of your 285/60/18 tires?
  13. Dec 30, 2009 at 11:36 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I believe they are called 32s but are actually 31.5 or so brand new...checking nitto spec site.........according to nitto's site , they are 31.38 and 11.54 footprint
