5100 lift questions
Discussion in 'Suspension' started by TacomaTRD88, Mar 14, 2013.
  1. Mar 14, 2013 at 7:24 PM
    TacomaTRD88
    TacomaTRD88 [OP] Well-Known Member
    Illinois
    '12 Double Cab TRD Off-Road
    I have a 2012 double cab TRD Off Road edition and I will soon be ordering 5100's for my entire truck. I hate to say it but I doubt that I do much off roading, just want to have a truck that looks good and will ride close to stock on the highways, which is where I do most of my driving. I do have a few questions:
    1. I'm going to go with some 16x8 Method Double Standard Wheels and 265/75/16 Goodyear DuraTracs. I want to go 1.75 to level out my truck. I was told that I should order these Camburg UCA's:
    http://camburg.com/store/05-12-taco/toyota-tacoma-performance-balljoint-upper-arms/
    My question: Do I need to order UCA's for my truck, and if so, what are brand suggestions? Someone on here told me that the Camburg UCA's won't help my ride.
    2. I was also told that I should install a differential drop. I have read mixed reviews on them. Opinions?
    3. I have seen some people install 5100's and end up with a bro lean. Is this something that happens from time to time? Any way to avoid it?
    4. Are there any other suspension components that I'm forgetting?
    Thanks for any input!
  2. Mar 14, 2013 at 7:31 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    1)When you lift your front to 1.75, you don't need new UCAs. Your stock ones should be fine.
    2)Differential drop doesn't do anything to our 2nd gen.
    3)Every truck is different. From what I've seen, with the front at 1.75, your nose will be a little higher. A tad higher. You can either set your 5100s down to .85, run a rear block (not recommended), or run an AAL.
    4) You'll want a 1/4" top plate spacer to correct the driver side lean.
  3. Mar 14, 2013 at 7:37 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Seems like a thousand different suggestions for every set up. 2012 DCLB Sport, 5100's set @ 2.5'' with stock coils and TSB rear is what I run and it sits level. Stock UCA's and alignment in spec. No diff drop, no vibes.
  4. Mar 14, 2013 at 8:58 PM
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    Does anyone have the specs for that spacer plate? I run a CNC waterjet and could cut my own for free... Thanks
  5. Mar 15, 2013 at 5:10 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
  6. Mar 15, 2013 at 5:31 AM
    TacomaTRD88
    Illinois
    Could you explain the TSB process you went through? I have read threads on it, but still don't quite understand it.
  7. Mar 15, 2013 at 6:16 AM
    Boone
    Boone, NC
    Airbags deployed
    Went to look at the truck before purchase, asked them if they could take care of it before papers were signed and they did. It's just something that you'd have to talk to the dealer about. they should do it no problem if it's under warranty. If not I'd just go with some Dakars or Alcans.
  8. Mar 16, 2013 at 12:13 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    its just adding an extra leaf to the stock rear pack. It was not on a lot of the american trucks when the 2nd gen started
  9. Mar 18, 2013 at 3:03 PM
    DBroman3
    DBroman3 Member
    Don
    Irvine, CA
    2013 PreRunner SR5 2.7 4x2
    Working On it
    Boone Taco, Any cutting needed for your 285's with only using 5100"s @2.5 in the front? I have a 2013 DC and I really want to just throw 5100's @ 2.5 and some 285's and call it done...
  10. Mar 18, 2013 at 4:16 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    covered many times. You will need to cut some plastic. Maybe do the cab mount chop too depending of how bad it rubs. Its easy as fuck though
  11. Mar 25, 2013 at 2:23 PM
    DBroman3
    DBroman3 Member
    Don
    Irvine, CA
    Working On it
    Yeah, I see different results all over the place. Just asking what you did, more importantly, did you do the cab mounts?
  12. Mar 25, 2013 at 3:21 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    not yet, but i have the 2 plates to weld there and will be doing it soon
