5100 lift with stock UCAs
Discussion in 'Suspension' started by danteisme, Jul 25, 2011.
  1. Jul 30, 2011 at 8:12 PM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    Depending on how hard you wheel you may want to consider the angle on the upper ball joints with the 5100's at 2.5. I busted both of my ball joints on stock UCA's at 2.5. 1.75 seems to be the best of both worlds. You can always adjust them later too if you end up getting UCA's down the road. Once you start modifying your truck its hard to stop :D
  2. Aug 9, 2011 at 6:47 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    at 1.75 front and rear, should i buy any shims or anything else in case i need it? i'm trying to buy everything i need all at once so i'm not waiting on parts.
  3. Aug 9, 2011 at 6:51 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're just lifting the front to 1.75", you wouldn't need anything. Rear 5100's are not adjustable and do not provide any lift, therefore you do not need shims or a CB drop kit since you aren't changing any of the driveline geometry in the rear.
  4. Aug 9, 2011 at 6:57 AM
    acdronin
    acdronin Well-Known Member
    Just loaded 5100's at 1.75, had it aligned the next morning, things were out of spec fer sure so definitely get it aligned right away.
  5. Aug 9, 2011 at 7:16 AM
    danteisme
    South Western PA
    ooops, forgot to note i'm getting the 1.75 AAL for the rear.
  6. Aug 9, 2011 at 7:16 AM
    danteisme
    South Western PA
    any other problems other than the alignment? i figured that'd be out of wack.
  7. Aug 9, 2011 at 7:20 AM
    Pugga
    Massachusetts
    Haven't seen a 1.75" AAL, you'll have to choose between 1.5" and 2" AAL. I bought a CB drop kit when I did mine but have never installed it. For an extra $5, it's not a bad idea to grab one along and save on shipping. You might not need it though so your call.
  8. Aug 9, 2011 at 7:27 AM
    danteisme
    South Western PA
    argh, i typed to quick. you're right. i mean the 1.5" AAL.
