5100 lift
Discussion in 'Suspension' started by sinaloa226, Feb 9, 2011.
  1. Feb 9, 2011 at 8:48 PM
    sinaloa226
    sinaloa226 [OP] SIINALOA 226
    PATTERSON, CA
    10 DC 4X4,
    POWDER COATED WHEELS, KM2, LEATHER INTERIOR
    Thinking of going the bilsteins 5100 set at 1.75 and eibach springs to get a full 3 in of lift. Had anyone have had problems with this setup?
  2. Feb 9, 2011 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That would give you over 3" lift, and kill your CV's.
  3. Feb 9, 2011 at 8:52 PM
    sinaloa226
    PATTERSON, CA
    10 DC 4X4,
    So how would i get 3 in?
  4. Feb 9, 2011 at 8:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Set the 5100's at the .85" setting, and that will give 2.5", or a little more. Much better for your CV's.
  5. Feb 9, 2011 at 8:57 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    2.5" is probably all you want for your cvs... but people get 3" all the time with OME
  6. Feb 9, 2011 at 8:58 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    toytec says you can set the shocks on the second c clip with the eibachs and get 3 inches an if you worried about cv boot get a diff drop kit
  7. Feb 9, 2011 at 8:59 PM
    sinaloa226
    PATTERSON, CA
    10 DC 4X4,
    Ok thanks
  8. Feb 9, 2011 at 8:59 PM
    sir1123
    Charleston
    "1.5 to 3" lift kit with Eibach front coils (3" average lift is achieved with coils and setting the shock adjustment on the second C clip setting from the bottom) DO NOT EXCEED THIS SETTING OR DAMAGE CAN OCCUR"
    from toytec page
  9. Feb 9, 2011 at 9:01 PM
    Yoytoda
    Roland
    completely stock
    FYI diff drops dont do anything...
  10. Feb 9, 2011 at 9:03 PM
    sir1123
    Charleston
    how so?
  11. Feb 9, 2011 at 9:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  12. Feb 9, 2011 at 9:06 PM
    sir1123
    Charleston
    so they dont help witht the angles orrr.........
  13. Feb 9, 2011 at 9:10 PM
    Yoytoda
    Roland
    completely stock
    they only rotate the diff... not drop it... they go under the front mounts thus lowering the front and rotating the rear mount (which is the axle) so it doesnt actually drop the axle... so cv angles dont change.
    they can actually possible do more harm because the make the diff mounts more prone to damage and the also rotate the pinion to be high and not is the oil as much. With good oil it shouldnt matter but is something to think about
  14. Feb 9, 2011 at 9:12 PM
    sir1123
    Charleston
    but the front does actually drop though.?
  15. Feb 9, 2011 at 9:15 PM
    Yoytoda
    Roland
    completely stock
    the front of the mount...
    hold a pencil (axle mount) by the eraser in you thumb and index finger. image the eraser is the axle (perpendicular to the pencil). if you lower the tip of the pencil the eraser only pivots, it does not get lower
  16. Feb 9, 2011 at 9:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The front of the diff, Yes. But not the axels.....not enough to actually help the CV's.
  17. Feb 9, 2011 at 9:18 PM
    sir1123
    Charleston
    well good thing i have a prerunner....no cv's.... but thanks for the new info appreciate it
  18. Feb 9, 2011 at 9:23 PM
    Yoytoda
    Roland
    completely stock
    stupid illustration i made... you can see with the front bracket lower the axle stays the same height, it just rotates...
  19. Feb 9, 2011 at 9:24 PM
    sir1123
    Charleston
    so why even make em?
  20. Feb 9, 2011 at 9:36 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    So is it worth the $30?
