5100 options for 2"? (Sorry bout it)
Discussion in '4 Cylinder' started by itsryan, Mar 18, 2014.
  1. Mar 18, 2014 at 12:35 PM
    itsryan
    itsryan [OP] Active Member
    Chino Hills
    11 4banger 4x4 SR5- sold
    2.5i 2015 Subaru Outback
    Sorry for making the millionth bilstein 5100 thread, but I've read the endless threads on TW and cannot find the answer im looking for......... :confused:
    I want to lift my truck to have a solid 2in lift, NO MORE (I want to keep stock uca) . I already have some adjustable 5100s im waiting to put on the front and, just have stock rear 3 leafs (no tsb leaf). I want raise it level. I also have a fiberglass shell idk if that matters. How can i do this?
    Can I use my 5100 @ 0 with Eibach Coils(=1.6'') and then use a .5'' and .25'' spacer to get near 2''? (.5 driver for taco lean)
    And for the rear- since i don't have the tsb leaf And have fiberglass camper
    what would be my best option to match front?
    from what i read the 4cyl access cab weighs less than v6, so i will have more lift than what the v6 guys claimed to get. is this true?
  2. Mar 18, 2014 at 12:43 PM
    CO Taco
    CO Taco Texas Aggie
    Tyler
    Fort Collins, CO
    08 SR5 4x4 Black
    Weather Tech Mats, GTA aux adapter, Plasti-dip emblems, radio
    if you want 2'' because you just want to level it out, you just need to set the 5100s to 1.75 setting, esp if you don't have the TSB in the rear.
    it still may be a little nose high but then should settle. Don't know how much your topper is weighing the rear down, but I think the 1.75'' setting is the way to go imo
  3. Mar 18, 2014 at 12:47 PM
    Onurnez
    Onurnez Well-Known Member
    Richmond, Virginia
    2008 Toyota Tacoma
    Fog Light Anytime Mod, LED dome and Map, Alpine Head unit, w/ Alpine door replacements, De-badged/De-Flapped, Anzo Black Headlights, Anzo Black Tail lights, Satoshi by Homer, Full OME Kit, LR UCA's Black interior dash parts, UltraGauge, Custom Decals By RuggedT, TRD Exhaust, Volant CAI, Weathertech Rainguards, Weathertech Floormats, Blueinstinct Center and door handle covers, Tacoma Bed Mat, 17x9 Fuel Kranks, 285/70/17, Window Tint: 5% back/35% front, Powerslot Rotors, Redline hood strut, 14'' Black Billet Antenna, LED Bed Light Mod, 100k mile mod
    I don't know if this is going to help you or not. That being said;
    I have eibach coils and 5100's set at .85. I have a 2 inch AAL in the rear non-tsb and my rear sits .5 inches higher than the front.
    I do not have a shell and I do not know the weight, but it seems if you do the eibach at 1.6 and get a 2 inch AAL in the rear, you will be damn close to level.
    Just a little lesson I learned, you should get UCA's.
    My .02
