5100 Purchase
Discussion in 'Suspension' started by ccurtis0805, Jul 10, 2012.
  1. Jul 10, 2012 at 6:25 PM
    ccurtis0805
    ccurtis0805 [OP] Well-Known Member
    cale
    South Florida
    2010 SR5 4x4
    5100s all around, rear tsb, interior LEDs (center console, driver & passenger side floor boards, glove box, under a/c controls, rear cupholders; BHLM; DIY Satoshi
    Just ordered the billy 5100s for all four corners. Stoked!
    Question 1: kind of dumb to ask now (always been trigger happy), but if I were to want to do a 3" lift down the road will I be able to use the 5100s.
    Question 2: will I be sacrificing ride quality if I set the fronts at 1.75? 1.75 is the setting to level out the truck, right?
  2. Jul 10, 2012 at 6:28 PM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    yes
    yes from my understanding but not sure how much or if its measurable.
    if you did your 3" lift you would need to set your 5100's at 0. you also would need a source of lift in the rear.
  3. Jul 11, 2012 at 7:50 PM
    Alby22
    Alby22 Active Member
    Al
    Ashville, Ohio
    2007 Toyota Tacoma Double Cab 4x4 Sport
    Blacked out headlights, Tonneau cover
    I'm looking to buy the 5100's for my 2007 4x4 double cab sport. If you don't mind me asking, where is the best place to buy them from, and how much did you pay for them?
  4. Jul 11, 2012 at 7:50 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
  5. Jul 11, 2012 at 9:22 PM
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
  6. Jul 11, 2012 at 9:50 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    No it can be. I just used it today. Came out to 175
  7. Jul 11, 2012 at 9:58 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    edit im a derp
  8. Jul 17, 2012 at 11:52 AM
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    Just got the UPS text message that my billies have arrived! :bananadance::woot::goingcrazy:
  9. Jul 17, 2012 at 12:18 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Mine will be here tomorrow! Can you adjust the settin on the 5100s without takin them all the way back off?
  10. Jul 17, 2012 at 12:23 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    you can adjust before install, but not while they have a spring on them.
  11. Jul 17, 2012 at 12:24 PM
    bjhn83
    bjhn83 Well-Known Member
    Bradley
    Columbia, MO
    05 SR5 DCSB Grandpa Shell
    3" Toytec lift, 285/75/16 BFG AT KO's on Pro Comp 7089's, Yellow fog lights, Satoshi
    Nope its a ring around the piston that has to be moved. Springs have to be decompressed and removed. Far more adjustable than new shocks though :D
  12. Jul 17, 2012 at 12:27 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Haha well dang. I'm just worried if I set them at 2.5 inches I'm not gonna like the way my truck looks with only 265/75/16s
  13. Jul 17, 2012 at 12:31 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    1. buy bigger tires.
    2. remove and set it at a lower setting.
  14. Jul 17, 2012 at 1:34 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Well Ill have to wait a little but before I get new tires. I can't justify buyin new ones when my bfgs still have goo tread
  15. Jul 17, 2012 at 9:42 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The bigger issue is whether or not you can get it aligned right at 2.5". I could not.
  16. Jul 18, 2012 at 4:11 AM
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    So, I took out the shocks to inspect and prepare for my install. Is there a special tool that is needed to adjust the shocks to the different lengths (.85, 1.75) or does that piece just slide down, turn, and set in place?
  17. Jul 18, 2012 at 6:36 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Mine are supposed to be at my house by 12. I've been wondering the same thing. Also I wanna put mine on tonight but because of work I won't be able to get an alignment till Saturday. Will I be fine to drive on it till then?
  18. Jul 18, 2012 at 7:20 AM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    yesh
  19. Jul 18, 2012 at 8:47 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It just snaps into whatever height you want. No tools needed for that part.
    Make sure you don't install the spring perch upside down, it's very common. If installed correctly, the perch should look like a bell shape.
  20. Jul 18, 2012 at 8:52 AM
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    Thanks! Is there any problem running the 5100s with the stock sr5 coils?
