5100 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nb_tacoma, Feb 21, 2011.
  1. Feb 21, 2011 at 4:46 PM
    nb_tacoma
    nb_tacoma [OP] Well-Known Member
    nick
    Thunder Bay, ON
    2006 SR5 access cab 4x4
    2.5 inch toytec lift /w rear block 255/85/16 cooper discoverer st's Westin light bar with 2 hella 500's Satoshi grille mod BHLM bumper valence painted with rocker guard relocated the horns tail gate anti-theft mod added a trailer hitch relocated 7 pin in bumper rear diff breather mod Magnaflow muffler kenwood KDC-X895 deck
    Hi all,
    I currently have a 2.5 inch spacer lift with an aal rear
    And would like to know if I bought 5100s if I could keep
    The spacer lift in with it and Achieve more lift this way
    or would I have to remove The spacer lift for it to work
    Thanks
  2. Feb 21, 2011 at 4:53 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Yes you can keep the spacer
  3. Feb 21, 2011 at 4:54 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ^ sarcastic reply?
  4. Feb 21, 2011 at 5:11 PM
    n315on
    n315on Well-Known Member
    MA
    02 4x4 SR5
    3'' toytec lift springs wrapped around 5100's. Deck plate mod. TRD seat belt pads. JL audio amps /subs and Alpine speakers. Diff breather mod. Working on a custom rear bumper
    Just ditch the spacer and set the 5100's at 2.5''. If you want more lift you could get a .5'' top plate spacer and this would achieve 3'' of lift (the max recommended for your CV angles) Keep in mind that with 3'' of lift you may not be able to get your alignment dead on, unless u get some UCA's.
  5. Feb 21, 2011 at 5:13 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    This
  6. Feb 21, 2011 at 5:13 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    it is not exactly recommended to combine lifts,your CV's will hate you if you go to much.
  7. Feb 21, 2011 at 6:01 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The shocks will hate it more, considering you will remove all of the down travel.
  8. Feb 22, 2011 at 1:19 AM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Nope, he could keep the spacer; but as others stated it isn't recommended and wouldn't be smart...
  9. Feb 22, 2011 at 5:45 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    As 98tacoma27 noted, the shocks will basically be topped out with a spacer and the billys set at 2.5 together.
    Saying he "Could do it" but it's "not recommended" is like saying "You could walk out in front of a bus, but I wouldn't recommend it" :D
