5100 question
Discussion in 'Suspension' started by shadow, Aug 25, 2009.
  1. Aug 25, 2009 at 7:43 PM
    shadow
    shadow [OP] Member
    Louisiana
    06 TRD 4x4
    if i set the 5100s at 1.75 and then later decide to lift them to 2.5 is it difficult? do i need to compress the springs again? thx
  2. Aug 25, 2009 at 7:45 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    welcome! and to answer both questions at once, yup!
  3. Aug 25, 2009 at 7:45 PM
    TengoTaco
    TengoTaco Wish i was wheelin
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    You will need to compress the springs again,
  4. Aug 25, 2009 at 9:01 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Yes,
    Best bet is to adjust to 2.5 right away. Personally, I don't think it's that difficult to do...more tedious than anything else. It's a straight forward install and having the right tools at hand helps quite a bit.
    Any reason as to why you would go with the lower setting first as opposed to doing the full 2.5?
    Kind Regards,
  5. Aug 26, 2009 at 9:37 PM
    beginah
    beginah Well-Known Member
    I would set it to 2.5 from the start (i have a toytec 2" AAL). i set it at 1.75 and wasn't happy with it, so i just adjusted it today. you do have to take it all apart and compress the spring. at 2.5, i'm about 1/2 taller in the rear. the only good thing was that it was super fast the second time around.
