5100 questions...
Discussion in 'Suspension' started by 05RedTaco, Sep 26, 2012.
  1. Sep 26, 2012 at 8:12 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I got a front and rear set of Bilstein 5100's. Right now I have stock TRD Off Road shocks with 3" spacer up front and 2" AAL in the rear.
    I am planning to install the 5100's in the front set at 2.5 with stock coil. What are disadvantages of that setup as opposed to run the 5100's with OME 885's?
    Also will the 5100's set at 2.5 with OEM coils make my truck lower than it is now with the spacers?
  2. Sep 26, 2012 at 8:16 PM
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    The advantage is that you may not need UCA's at 2.5 inches rather than a 3" lift.
    Your truck should be lower. I first had a 3" spacer lift for 20k miles and it messed up my stock UCA's. I then went to the Billies and my alignment was better and no wear on the UCAs
  3. Sep 26, 2012 at 9:05 PM
    05RedTaco
    Tony
    Scottsdale
    Thats good news, because even after I got my truck aligned my front tires are still slightly \ / ...
    So in order to do 3" lift the right way I would need the 5100's with OME 885's and aftermarket UCA's correct?
  4. Sep 26, 2012 at 9:14 PM
    YumaTRD
    David
    Solid Axle Yota
    Correct
  5. Sep 26, 2012 at 9:14 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    I got 2.75" of lift with 5100s @ 2.5" (stock coils).
    upgraded to 885x coils and LR UCAs (5100s @ 0"), which put me 1/8" higher compared to 5100s @ 2.5".
