5100 questions
Discussion in 'Suspension' started by jc75754, Sep 28, 2012.
  1. Sep 28, 2012 at 9:16 AM
    jc75754
    jc75754 [OP] Member
    Justin
    North Carolina
    2001 tacoma
    Noob and need advice.
    I have a 2001 Taco and need a new struts. I am not really a technical guy so any advice would be appreciated. I was looking at the Bilstein 5100 leveling struts and going all around with these and replacing the stock coils on the front.
    I only wanted to get about one inch out of the struts are these my best options. Or should I go with another brand.
    Also I have no idea what all would need to be changed out with the new struts. What other parts would I need?
    What would also be the best coil spring set for the front?
    Here is the problem. I am trying to do this all for under 400 or close to that.
    Thanks for any help.
  2. Sep 28, 2012 at 10:32 AM
    jc75754
    jc75754 [OP] Member
    Justin
    North Carolina
    2001 tacoma
    found one answer to my question. The coil i want to use is a 885 oem and only lift to .85.
  3. Sep 28, 2012 at 10:36 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    885's are for second gen tacomas. You want the 880 which will give you 1". Keep the 5100 at the 0" setting
  4. Sep 28, 2012 at 10:53 AM
    jc75754
    jc75754 [OP] Member
    Justin
    North Carolina
    2001 tacoma
    awsome thank you. Isaw that in a sticky above. As far as ordering other parts what is needed?
  5. Sep 28, 2012 at 10:57 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If you just want to lift the front, you just need the 880's and 5100 shocks. You don't need anything for the rear as far as lift if you just want to level the front up
