5100 Rears (boot up or down?)
Discussion in 'Suspension' started by 02sr5trd, Aug 26, 2012.
  1. Aug 26, 2012 at 10:34 AM
    02sr5trd
    02sr5trd [OP] Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    Well I am about ready to install my rear 5100's. I have seen a thread (cant find it now) where the guy installed his with the boot up, and others commented on it that it was upside down. I have always thought they we supposed to be boot up? Dose it matter which way they go or is there any benefit to either way? Thanks guys!
  2. Aug 26, 2012 at 10:41 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    With 2nd Gens there is no option, it's boot up. That might be for a reason :notsure:
  3. Aug 26, 2012 at 10:45 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Thanks, Yeah im assuming they should be boot up. Although they have a boot it would help keep the road grime/mus/snow from getting to it as easily.
  4. Aug 26, 2012 at 11:00 AM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    It does not matter.
    However, bilstein text on the shocks indicate it is right side up when the shaft is on the bottom.
    I've ran mine shaft down forever and have never had an issue.
  5. Aug 26, 2012 at 11:06 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Thanks.
    Yeah, I did notice the stickers were that way. I just wantet to be sure before I stick them on.
  6. Aug 26, 2012 at 2:15 PM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    I decided to put them boot up.
  7. Aug 26, 2012 at 2:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Boot down is technically better, less chance of mud sitting on the seals. Also if it matters (it doesn't) there is less unsprung weight with the shaft pointing down.
  8. Sep 30, 2013 at 11:19 AM
    Dietter700
    Dietter700 Well-Known Member
    Troy
    Montgomery County PA
    Taco TRD off road
    Not saying your wrong at all, bc other shock manufactures could be different but I was hesitant to put boot down on mine even tho the logo is upside down bc a friend of mine put his boots down and kept on blowing out his seals. The reason he mounted them upside down is the exact reason you just stated. After 2 shocks under warranty the manufacture finally asked what way he was mounting them . He told them and they said that is why they are blowing out. I believe that was a pro comp lift and it was on a full size pick up. If billstein says to mount the 5100s boot down I may switch mine. Kinda torn.
  9. Oct 1, 2013 at 9:56 AM
    Clown Baby
    Clown Baby Well-Known Member
    Eric
    NorCal
    '00 prerunner
    FWIW, I did mine a couple weeks ago and went boot-up. Figure there's less chance for something to snag/tear the boot up there.
    Had to argue with my buddy who kept saying boot down because of the way the sticker was stick on the shock.
  10. Oct 1, 2013 at 11:20 AM
    stikle
    stikle Well-Known Member
    Seth
    Milwaukie, Orygun
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    If the sticker says boot down, you might want to do that or risk voiding your warranty. Probably wouldn't happen, but sometimes all a manufacturer needs is a reason.
  11. Oct 1, 2013 at 12:14 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Boot up or boot down, all depends on the particular shock and part #. Bilsteins should be installed so that the sticker and writing on the shock is right side up for proper compression/rebound valving.
