5100"s and rear tsb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hockeydad, Jul 17, 2011.
  1. Jul 17, 2011 at 3:19 PM
    Hockeydad
    Hockeydad [OP] Member
    So Cal.
    11 TRD Off Road Prerunner
    5100's and tint so far.
    Has any one had the 5100"s set at 1.75 and stock rear springs and than got the rear tsb done, if so did the ride get much stiffer. The reason I'm asking is because i have the stock rear springs now and the ride is perfect for me.I'm wondering how much stiffer will the ride get if i do the rear tsb replacement springs.Thanks for any info.
  2. Jul 17, 2011 at 6:19 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Richmond, Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's (.85), Eibach Coils, AAL, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, 4% Tinted Windows, Weathertec Floor Liners, Double Din Pioneer Player, 2 10" Memphis SR Subs, Plasti Blacked out Bumper, Grill, & Emblems, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Storage - Rotopax, Pelican 1600 waterproof case, Plano 42"case.
    There is 1,000 topics on this. Do a little search and you will find more than enough info that you need. I learned a whooooooollllee lot of stuff researching the forum.
  3. Jul 18, 2011 at 12:03 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Do the tsb, to me i couldnt tell a difference in the ride...
  4. Jul 18, 2011 at 12:21 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I just had the rear tsb done on the 8th. I have the original shocks also. The ride is much better. I don't feel every little bump like I did pre-tsb. The truck is stiffer & much less body roll when cornering. I drive mine like I stole it, so it has helped with cornering. I haven't carried any heavy loads since the tsb. The back is about 2" higher than it was when stock.
  5. Jul 18, 2011 at 12:28 AM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    My question is why are guys with 2011 tacomas needing a tsb spring? Should they already put that on standard now?
  6. Jul 18, 2011 at 12:32 AM
    BulletToothTony
    That would make to much sense wouldnt it :D. But my personal opinion is most people that buy trucks now are used to having a soft comfy ride in cars suvs etc. so they expect it to carry over to a truck. Now people that buy a truck and use it like a truck need the tsb (IMO). Thats why i got (that and a little free lift didnt hurt :D).
  7. Jul 18, 2011 at 1:06 AM
    genxer36
    Sean
    Bethlehem,GA
    Toyota does it for several reasons. It saves the company money is probably the number one reason. Most people never haul heavy loads & would not need it. When I had my tsb done, the service writer told me the parts were $1800. Paid for by Toyota. :)
    Toyota did make a change for 2011. With the tsb they do not change the shocks, like they did in previous years. The trucks have the updated shocks.
  8. Jul 18, 2011 at 6:04 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    X100- it's like that movie Groundhog Day...
  9. Jul 18, 2011 at 6:15 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If the ride is perfect, why are you contemplating the TSB? The TSB was created to fix a problem that it sounds like you're not having.
  10. Jul 18, 2011 at 6:48 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    Where's KPT? He has that setup and would tell you how he likes it
  11. Jul 19, 2011 at 8:25 AM
    Hockeydad
    So Cal.
    The reason I'm contemplating is I'm worried about towing watercraft or boat if its going to bottom out.Also I would like to see how much it will lift the rear I don't want to have much of a rake look.
  12. Jul 19, 2011 at 8:36 AM
    Pugga
    Massachusetts
    F-150 Mod
    That's kinda my point, if it bottoms out, then get the TSB. If your stock pack handles the weight and you like the ride when it's unloaded, why change it? Not trying to give you a hard time, just very much an advocate of if it ain't broke, don't fix it :D
    To answer your original question though, the ride is definitely stiffer. The truck doesn't roll as much in corners and handles weight much better.
  13. Jul 19, 2011 at 11:32 AM
    genxer36
    Sean
    Bethlehem,GA
    Boats have zero effect on sag. The tongue weight is minimal. Hook up a boat &I you won't see any dip. I tow an 18' Ranger bass & had zero sag issues on my 2005 & 2011 non TSB tacomas.
    The TSB is only needed if you carry or plan to carry heavy loads.
    I had the TSB done, because I plan to carry sod & stacked stone next year for my yard makeover.
    For me the TSB eliminated feeling the small bumps in the road. The big bumps are more prevalent.
  14. Jul 20, 2011 at 8:23 AM
    Hockeydad
    So Cal.
    Thanks for the for the responses its been very helpful.
