5100 set at 0.85 with 10 mm top spacer and Rear TSB
Discussion in 'Suspension' started by 5280EM!, Feb 6, 2011.
  1. Feb 6, 2011 at 6:10 AM
    5280EM!
    5280EM! [OP] Well-Known Member
    Thornton, CO
    Satoshi Grill
    Weird question but I thought I would throw this out.
    So I have been reading tons of topics and searching for this question and couldn't find an answer. Does any body have this set up?
    The reason I ask, is 5100 at 0.85 still has the factory rake and 5100 at 1.75" is either level or slightly higher than the rear. If I set the 5100 to 0.85 the shocks should still have enough travel for a smooth ride and still give me a even lift.
    So with 5100's set at 0.85" along with a 10 mm top spacer. This should yield a 1.35", lift unless I am wrong. Please do not bash on me since I am a noob at doing truck lifts.
  2. Oct 12, 2012 at 5:11 PM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    Found the above post when researching suspensions on here. Would like to hear an opinion on it...
  3. Nov 12, 2012 at 8:40 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Funny, I was thinking about this too and then I found this thread. Bump.
  4. Nov 12, 2012 at 8:44 PM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    FWIW... I ended up getting Eibach coils and setting the 5100's @ 0". Lift was the advertised 1.6", my rear is only 0.5" higher w/ TSB (basically level), and I couldn't be happier.
