5100 set at 2.5 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiatt1991, Oct 15, 2011.
  1. Oct 15, 2011 at 10:36 PM
    Hiatt1991
    Hiatt1991 [OP] Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Hey guys I'm buying some 5100s this weekend from down south motorsports. I will be using the stock coils for now. I'm looking to have the front end higher than the front so I am looking to set them at 2.5. I am an 05 trd Offroad non 4x4. Basically I was wondering if this setup would hurt my truck at all or if I'd get any vibes and if all I'd need are the shocks. I see that 4x4s are the ones that have troubles with vibes, but I just want to be sure.
  2. Oct 15, 2011 at 10:39 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
  3. Oct 15, 2011 at 10:50 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    You should be fine at 2.5 or less. I had a vibe when I installed my 5100's but it turned out to be one of my wheel bearings. I guess I'm one of the lucky 4x4 guys with no vibes. :)
  4. Oct 15, 2011 at 11:11 PM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    2.5" w/stock springs, no problems,also with the 1/4" driver spacer for the taco lean
  5. Oct 15, 2011 at 11:35 PM
    Hiatt1991
    Hiatt
    Sorry. Dumb phone. I meant I want the front higher than the rear.
  6. Oct 15, 2011 at 11:51 PM
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    You should be fine. Some trucks do have problems with stock UCA's with billies up front at 2.5 and some trucks are fine with stock UCA's, it's usually hit or miss. So Light Racing upper control arms from fat bobs garage might be something to look into for optimum allignment.
  7. Oct 16, 2011 at 12:34 AM
    Hiatt1991
    Hiatt
    Thanks fellas! I should have pics sometime soon. I've settled on doing 2.5
  8. Oct 16, 2011 at 9:14 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Make sure you have a healthy set of spring compressors. I set mine at 1.75. My spring compressors were at there breaking point.
  9. Oct 16, 2011 at 12:44 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I have my blistens set for a 2.5 lift and put ebiach springs on them. With the rear TSB, My ride height is perfect. No UCA changed. Alignment came out perfect when re-aligned. Rides and handles very well. Mine is an access cab 4x4 if that means anything to you.
