5100 suspension question
Discussion in 'Suspension' started by hwork50, Dec 1, 2009.
  1. Dec 1, 2009 at 9:15 PM
    hwork50
    hwork50 [OP] Well-Known Member
    San Clemente
    06 PreRunner SR5 AC
    DTRL, Skid Plate, Bed Extender, ipod hook up in glove bo, bed mat, rubber mats, Garmin GPS, 2.5"Toyotec lift with 5100 shocks and Eibach springs.
    I just installed the 5100 suspension from the group buy. I bought the toyotec package and installed it with the coils in front and the aal in back. I did not put the AAL in as my mechanic thought it was too much.
    My question is the back bottoms out when I go over speed bumps and it is really irritating as my other shocks did the same thing in the front which is why I got the new suspension. I did load the truck up with a lot of concrete a week earlier but that was prior to my new suspension.
    Will the AAL fix this? Is there anything that could cause this?
    Brent
  2. Dec 1, 2009 at 9:18 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    The aal should help keep it from bottoming out. What setting did you use for the front 5100's?
  3. Dec 1, 2009 at 9:29 PM
    hwork50
    San Clemente
    06 PreRunner SR5 AC
    The front ones are totally fine. I think I have them set at like 2.5. The truck is totally level. I did call Toyotec and they said to put in the AAL and that should solve it.
    I just dont want to jack up the rear as I love how the front responds and drives now.
  4. Dec 1, 2009 at 9:30 PM
    ajohnson
    Andy
    Charlotte, NC
    wait... are you using the eibach coils or factory coils?
  5. Dec 1, 2009 at 9:40 PM
    hwork50
    San Clemente
    06 PreRunner SR5 AC
    I am using the eibach coils that came with the group buy.
  6. Dec 1, 2009 at 9:42 PM
    ajohnson
    Andy
    Charlotte, NC
    You know you should set the 5100's at .85 at most don't you? With the eibach coils and 2.5 setting you could destroy those shocks.
  7. Dec 1, 2009 at 9:44 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    you definatly need to change the setting if you have them @ 2.5 go "0" and the AAL made a big diff when I put it in my '05
  8. Dec 1, 2009 at 9:48 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ya the most you should do when pairing up those larger springs with the 5100's is .85" for the shocks. the eibach springs are already longer offering lift but your extending the shocks at the same time which isnt the best idea.
    where did you get the install done, the person should have known how to do it properly?
    then for the rear: when you do the aal it will help with the bottoming out. this is toyotas solution as well to the bottoming out by adding an extra leaf in the back, obviously not that same one as toytec has, but it helps with the issue
    adding: if you want to get a little more from the front lift look on toytecs website and get the 1/2" top plate spacer and have the shop install the longer studs when they change your 5100 settings.
  9. Dec 1, 2009 at 9:49 PM
    ajohnson
    Andy
    Charlotte, NC
    x2!!!
  10. Dec 1, 2009 at 9:52 PM
    hwork50
    San Clemente
    06 PreRunner SR5 AC
    Thanks guys I will let my guy know.
    Brent
  11. Dec 2, 2009 at 3:34 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    My homemade spring compressor was stressing when I put the 1.6 eibachs at .85. I think 2.5 would have broke mine.
    I am sure the shop compressors could do it but I bet it is like riding with a solid front end!!
    They have a 2" and a 1 1/2" AAL I went with the 2" and it did raise the back more than I hoped for.
    I do expect some settling.
