5100
Discussion in 'Suspension' started by Priv16, Sep 29, 2016.
  1. Sep 29, 2016 at 4:34 PM
    Priv16
    Priv16 [OP] Well-Known Member
    Benjanin
    2017 Tacoma Off-Road
    Stock
  2. Sep 29, 2016 at 4:37 PM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    Call Headstrong Off-road and talk to Marie. I went with the 885 old man emu coils and the bilsteins set at 0" and an AAL in the back. Gave me 2.5" of lift all around. Was around $600 but I also got new UCA's. not sure you'd need them if you don't go a full 3"
    Priv16[QUOTED][OP] likes this.
  3. Sep 29, 2016 at 4:44 PM
    Priv16
    Benjanin
    Stock
    Good deal I'll give them a shout. What uca did you get.
  4. Sep 29, 2016 at 6:24 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    Light Racing
  5. Sep 29, 2016 at 8:10 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    How did you get it so cheap?
    Did you not by 5100's? Right now my kit is around $640 without UCA's.
    Priv16[OP] likes this.
  6. Sep 29, 2016 at 8:49 PM
    Priv16
    Benjanin
    Stock
    What kit do you have? Or setup
  7. Sep 29, 2016 at 8:52 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    He said he used bilsteins set at zero lift..... so he had 5100s.
  8. Sep 29, 2016 at 8:55 PM
    Tacotruck7
    SoCal
    Some terrible spacer/block lift that was on the truck when I got it. I'm looking at getting a new set up soon. Between Bilstein or OME shocks.
    Oh, my bad. I must have read that quickly and come to the wrong conclusion! lol :smash:
  9. Sep 29, 2016 at 9:01 PM
    inwood customs
    Dave
    Im at just about 600 without an aal in their cart....a cheap single aal takes it to $680.00
    Maybe theres a discount they offer.
    But id rec 5100 rears and a progressive aal
  10. Sep 29, 2016 at 9:07 PM
    Tacotruck7
    SoCal
    That's what I am at. OME set up is around $100 more.
    Now, you think 5001's are better than OME?
  11. Sep 29, 2016 at 9:12 PM
    inwood customs
    Dave
    Nope, srry if thats how my post read.
    If i was going with ome coils, id use ome struts.... but thats just me.
    I just meant 5100s on the rear because i didnt see it included when Jeffp213 posted his setup.
    Im tired
  12. Sep 29, 2016 at 9:37 PM
    Priv16
    Benjanin
    Stock
    Wait. So what springs did you all use with 5100 shocks?
  13. Sep 29, 2016 at 9:44 PM
    inwood customs
    Dave
    Since u said "you all"..... eibach
    But, 2nd gen
  14. Sep 30, 2016 at 7:28 AM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    I used the OME 885 springs. 5100's in all four corners and a Deaver AAL. Rides great.
    It's a combo deal through Headstrong. I paid $1100 for all of that w new UCA's. $650ish sounds about right without upper control arms.
  15. Sep 30, 2016 at 8:39 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Don't be misled by the fact that OME shocks are more expensive. That doesn't prove they are better. They have an issue when used on 2nd gen Tacoma's. They are shorter than the Bilstien 5100. With that, the OME shock tends to run out of travel, resulting in the shock "topping out", which in turn results in a loud "THUD". Among other places you'll hear this is when you go over speed bumps, or in some off road situations. Otherwise, it's a good shock, but arguably no better than the Bilstien 5100. All things equal, the 5100's are less money. In my book, that settles the issue of which is "better".
    I'm on my 4th Tacoma, 5th Toyota overall, and 17th 4wd. Not my first rodeo....43 years of owning 4wds.... Not claiming to know everything, but I've been around the block a time or 2. What did I use to raise MY 2011 TRD OR
    13937753_10107521970697289_1931633486973093650_o.jpg 23686113586_5c6d7e6d08_k.jpg newlift 002.jpg newlift 003.jpg newlift 004.jpg tacoobannon2.jpg Tacoma? Bilstien 5100's, set @ 0", OME 885X coils, 1/2" poly spacers on top of that to get a total of 3" of lift. I got 2.9 degrees pos. caster with stock UCA's. Not common, but it does happen. Typically, you can expect to need new UCA's with 3" lift. I used Deavers 2" AAL in the rear, along with a U-bolt flip kit. I got the "kit" from Marie @ Headstrong Off Road for $733 with struts assembled, shipped to my door. U-bolt flip kit brought the total to right at $800. It handles great, rides excellent, performs off road to my expectations, and looks great.
    JeffP213 and Priv16[OP] like this.
  16. Sep 30, 2016 at 3:03 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    What are the advantages to the u-bolt flip? I'm in the same boat as you minus the flip kit.
  17. Sep 30, 2016 at 4:08 PM
    Priv16
    Benjanin
    Stock
    Soooo use bilstein with bilstein?
  18. Sep 30, 2016 at 4:23 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    I'm pretty sure everyone in this thread has suggested Old Man Emu coils (OME 885X's). Seriously, talk to Marie.
  19. Sep 30, 2016 at 4:34 PM
    Priv16
    Benjanin
    Stock
    But they have a clunking problem?
  20. Sep 30, 2016 at 5:11 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    I'm pretty sure he was saying OME coils w OME struts
