5100's @1.75 or 5100's @ .85 with Eibach/Toytec springs front lift question
Discussion in 'Suspension' started by CreepyTm, Nov 19, 2013.
  1. Nov 19, 2013 at 9:02 PM
    CreepyTm
    CreepyTm [OP] Well-Known Member
    Long Island, NY
    Bug Out Battle Truck
    Line-X'ed CBI Rock Sliders, Avid Light Bar, Flowmaster 10 series, Painted Grill and bumper, OKLED 20, 5100's with TSB and AAL, Bed mounted M240G
    I have a 2011 Access Cab and currently have the Rear TSB with a Toytec 1.5 AAL.
    Up Front I have Bilstein 5100's set at 1.75 on stock springs. There is a noticble rake. I will be adding the ALL-Pro front plate bumper and was wondering If I add the Eibach/Toytec springs to the 5100's and set them at .85, will I gain any front lift over just having the 5100's on stock springs at 1.75.
    I understand that I will still have a rake but hopefully less than i have now, while coming closer to a more level truck and will not have to do any major upgrades like UCA replacement.
    I have searched and have not found any help on this, I'm sorry if this has been asked before, but i could not find it. Thanks all
  2. Nov 20, 2013 at 2:13 PM
    CreepyTm
    Long Island, NY
    Anyone? I'm looking to pull the trigger on the eibachs, but seeking some guidance first.
  3. Nov 20, 2013 at 2:17 PM
    Large
    Large Red
    Might sit level actually, eibach are stiff coils but you are an access cab and adding a front plate bumper.
  4. Nov 20, 2013 at 2:37 PM
    CreepyTm
    Long Island, NY
    access cabs front heavy as compared to DC's?
  5. Nov 20, 2013 at 2:40 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You will probably sit a little nose high actually since your only an access cab. My buddy installed the 5100's/eibach kit set at .85" up front with a 2" rear AAL and his truck sits perfectly level and hes a DCLB.
  6. Nov 20, 2013 at 2:48 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    what size engine? 4.0?
    typically the eibachs give 1.6" by themselves. add the .85" bump from the "C" clip on the shock and your very near 2.5" of lift up front. Ive researched that a plate bumper with sag the suspension around .5"-1"
    By adding the eibachs w/ plate bumper I think youll be near 2" or just under. Leaving you very close to level
  7. Nov 20, 2013 at 4:10 PM
    CreepyTm
    Long Island, NY
    Yes, 4.0...Its a TRD TX/Pro AC
    It sounds like the bilsteins set at .85 with Toytec/Eibachs is the way to go over just having Billys set at 1.75 and stock springs.
    As of Now from center hub to fender I'm 21.5 front and 24 rear. with the 1.75 Bilsteins in front and TSB with 1.5 AAL in rear.
    Thanks for your input so far.....
  8. Nov 20, 2013 at 4:16 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    DC's are heavier since they are bigger trucks but not by a lot.
    I also think the 5100's/Eibachs are the way to go.
  9. Nov 20, 2013 at 9:10 PM
    TacoJoy418
    TacoJoy418 Well-Known Member
    Blake
    Texas
    2013 TRD Sport 4X4
    Avid light bar Custom headlights, morimoto led fogs Bilstein 5100's 3" Lift coils and AAL BFGoodrich KO2's
    Okay so not to thread jack, I have a 12' tacoma and I was planning on using the Bilstein 5100 adjustable shocks with the eibach 3" coils. Is that okay? I keep reading that those coils shouldn't be paired with aftermarket coils or spacers.
  10. Jan 20, 2014 at 3:51 PM
    FlintsTaco
    FlintsTaco Member
    Tropix
    Sonoma County
    2013 Silver 4x4 Sr5
    20% Tint all Around Bilstein Adjustable lift kit with 5100 shocks LR UCA BAMF Cab Mount Chop MagnaFlow Exhaust 1.5 TSB AAL + 1" Block U-Bolt flip Kit
    Hopefully my experience can help shed some light for the next Person looking to get a lift from toytec.
    I have a 2013 Tacoma DC LB 4x4 and I wanted to lift my truck 3” to fit AT 285/70/17. I went with the BilsteinAdjustable lift kit with 5100 shocks from Toytec. This is what it reads on their website, I’m sure you all have seen it.
    “1.5 to 3" lift kit with Eibach front coils (3" average lift isachieved with coils and setting the shock adjustment on the second C clipsetting from the bottom) DO NOT EXCEED THIS SETTING OR DAMAGE CAN OCCUR”
    Double cab models may require top plate spacers for full 3" lift”
    Countless hours reading threads and talking to a Rep I pull the trigger and purchase the lift with the LR UCAs. Get it all installed, I even used their, “required top plate spacers for full 3" lift” a few days later my Standard Methods and Toyo AT II come in and the back of the tire hits the cab mount? I even had my body shop trim the finders so they wouldn’t rub. The shitty part is my Liftis only 2.5”. That means I got 2” with the bilstein and another .5” with thetop plate spacer? Not even close to 3" average lift? I call Toytec and because I already installed everything I can’t return it. FML So my only solution is jacking up the C-Clip to the top and using my stock coils, That’s how my buddy got his 2013 DC LB 4x4 done at Les Scwab and he runs 285s with noproblem. Since I have the 1.5 TSB im going with a longer shock in the rear and adding a 1” block. Ill have about a little over 3” in the front and 2.5” in therear. I also installed the sway bar re-locator ad Diff Drop. I’m hoping with LR UCA I’ll be able to go over 3” in the front without any problems.
    If I could suggest anything to anybody looking to fit 33” on their truck id spend the extra cash and get the ToytecUltimate Lift Kit '05+ Tacoma and the 2” tsb to keep you level so you can rake up the front shocks.
    Let me know what you guys Think? Im not really into spenidng more than I have to so I can look cool and hit the snow a few times a year, I off road but nothing crazy......
