5100's @1.75 w/OEM spring or Eibach @0
Discussion in 'Suspension' started by HB Taco, Aug 21, 2011.
  1. Aug 21, 2011 at 11:58 AM
    HB Taco
    HB Taco [OP] Well-Known Member
    Curt
    Huntington Beach, CA
    11 DC TRD OR 4x4 Pyrite Mica
    As the title states I've decided to go with a mild setup for now and run 265/75 on current wheels and stock UCA for now. I'm planning on loading it up and requesting to TSB for the rear and 5100's all around. This wont cost me a mint and should hold me over for a few years (well see). So I'm just trying to decide if I should buy the Eibach spring or not. I have the TRD OR springs and they will be compressed when I set the clip at the 1.75 setting so will it ride rough? Also my plan is to take the truck in and hopefully the dealer will order the TSB springs for me then the day before going back install the new front setup and get a free alignment in the process ??? LOL Will this work? and will it be worth it to get the Eibach spring? Thanks
  2. Aug 21, 2011 at 12:09 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    I have the rear tsb & just installed 5100s up front the truck rides nice
  3. Aug 21, 2011 at 12:11 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    Go with the eibachs set at 0 instead of the OME springs set at 1.75. You'll have a smoother ride that way because the eibach spring has a higher spring rate, and when paired with the Bilstein 5100's, it's like a match made in heaven.
  4. Aug 21, 2011 at 12:12 PM
    HB Taco
    Curt
    So you using the stock spring? and what setting on the 5100's?
  5. Aug 21, 2011 at 12:12 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    You wont like it. Not that it wont do what you specified your looking for, but everytime you see a tacoma rolling on 33s or log in to TW you are gonna wish you had went ahead and got what you really want...you know you want it
  6. Aug 21, 2011 at 12:15 PM
    HB Taco
    Curt
    Ok thats what I was looking for. Maybe I should get all the top plate hardware too = easy swap?
  7. Aug 21, 2011 at 12:20 PM
    HB Taco
    Curt
    I hear ya but for now it's a DD and 95% street so I dont want to kill MPG and have to buy all the other stuff to go to the next level. There seems to be sooo much more involved to go to 3" and 33's. That said you're probably right and I'll get there later. I'm just itchin to get some lift now and my budget is not much right now.
  8. Aug 21, 2011 at 12:25 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    I set them at 1.75
  9. Aug 21, 2011 at 7:36 PM
    rogerkamp8817
    rogerkamp8817 Well-Known Member
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    I have bilstein 5100 with factory trd shocks up springs up front. shocks set at 1.75. i've had this setup for a year and have been anxious to go bigger. should have gone with 2.5" setting up front but i don't want to do all that work again and realign.
  10. Aug 22, 2011 at 8:19 AM
    wombat
    wombat Well-Known Member
    Smoke Porterhouse
    North Cali
    2017 DCORSB 4x4
    I currently have 5100's set at 1.75. The ride is not bad but a little rough at times. However, I'm getting the Eibachs and am going to set my 5100's at 0. It's just cleaner than compressing the stock spring.
  11. Aug 22, 2011 at 8:30 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Get the Eibachs, setting the 5100's at 1.75 will ride very rough. The TRD Off Road has a progressive coil so the more you compress it or preload it the spring rate takes off. The TRD Sport and SR5's come with linear coils that would ride a little better when pre-loaded. Lift the truck with taller springs, it'll be a much better ride in the end.
    Also, I don't know if you'll get an alignment out of the TSB. They won't be touching the front suspension so I'm not sure if they'll align it for you or not (I'm not familiar with the new TSB). Just a heads up, you might want to ask the dealer that's performing the work.
  12. Aug 22, 2011 at 10:26 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Not to hijack the thread, but I'm kind of in the same boat as OP. For a daily driver, which springs give a smoother ride - OME 884s or Eibachs?
  13. Aug 22, 2011 at 10:32 AM
    Pugga
    Massachusetts
    F-150 Mod
    Depends on what you want. 884's have a lower spring rate so they'd be a bit softer. 884's are 588 #/in and Eibachs are 620 #/in (for reference, stock is 540). Eibach's are very 'planted' on the road. They don't allow the truck to roll in corners and don't dive when breaking. The 5100's do a good job dampening the Eibach's so you don't feel like you're riding on a hay wagon (for those that have never been near a farm and don't get the reference, hay wagons don't have suspension). I have never riden in a truck with 884's but I love the ride with Eibach's. FWIW, I drive mostly on pavement.
  14. Aug 22, 2011 at 2:52 PM
    HB Taco
    Curt
    Thanks for the info / advice, kinda what I was thinking. I will be ordering Eibach springs with the 5100's. The cool thing is I move things up down the road without too much trouble.
  15. Aug 22, 2011 at 8:11 PM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    So if I go with the Eibachs and 5100's set at 0 will I need a 1.5" AAL for the ass end or is that only if you set them at .85"?
