5100's @ 2.5 + 1/2" spacers = y/n????
Discussion in 'Suspension' started by brutalguyracing, Apr 6, 2010.
  1. Apr 6, 2010 at 5:11 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    okay i have 5100's @ 2.5 with stock coils and a 2" aal in rear no tsb done
    i want a little extra lift
    i want to install 1/2" spacers on the front and a 1" block in the rear
    is this okay or no????
  2. Apr 6, 2010 at 5:14 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    You will have a horrible ride
  3. Apr 6, 2010 at 5:16 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    A 1/2" spacer gives about 3/4" of lift. That's going to put you over the 3" threshold that most people say is the max.
  4. Apr 6, 2010 at 5:16 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    No, do not stack lifts.
  5. Apr 6, 2010 at 5:22 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    You can stack them just fine within certain limitations. The highly respected OME lifts come with a 1/2" spacer to do the exact thing the OP is talking about.
    I'd say you should probably stick with a 1/4" spacer either on the driver's side only for the lean or put one on each side for another 3/8" lift. That will put you right under the 3" mark.
  6. Apr 6, 2010 at 5:38 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    there is no stacking of spacers i dont have any spacers just 5100's at 2.5
  7. Apr 6, 2010 at 5:42 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    But both compress the coil you only want to compress it so much
  8. Apr 6, 2010 at 6:17 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thats what i thought
    thanks
  9. Apr 6, 2010 at 6:19 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Let me know how your ride is.
  10. Apr 6, 2010 at 6:22 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    should i be worried????^^^^^^^^^
  11. Apr 6, 2010 at 6:24 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Personally i wouldnt do it JMO.
  12. Apr 6, 2010 at 6:24 PM
    BigBawlzTaco
    BigBawlzTaco Wanna know how I got these scars?
    Forsyth,Georgia
    Chevy Avalanche
    Straight piped.
    or if you could find a cheap body lift on the internet somewhere.
  13. Apr 6, 2010 at 6:30 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    Dont do it man seriously. All its going to do is mess up stock suspension components not to mention your cv's. You can do it if you want and yes it will lift your truck a bit higher but is it worth it to you?
  14. Apr 6, 2010 at 6:34 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    OP, the thing i would be worried about is your upper control arm coming in contact with the coil at full droop. I would talk to toytec and see what they recommend.
