5100's @2.5 only have 2" lift
Discussion in 'Suspension' started by skrich72, Jun 7, 2011.
  1. Jun 7, 2011 at 12:43 PM
    skrich72
    skrich72 [OP] Member
    San Jose, CA
    '06 PreRunner
    Bilstein 5100's @ .85 Eibach Coils LR UCA's Toytec 1.5 AAL
    Hey guys, new to the forum
    Just installed the 5100's and set them at 2.5" , but the before and after measurements put me at 2.0"? I also seem to have that driver's side lean now as well. Do these OEM coils tend to sag over time? Truck is 2006 Prerunner with 65K miles.
    If I have to upgrade the coils, what is my best option with the 5100's? I'd like to have a real 2.5" or 3" (with new UCA's)
    Thanks for your help ...
  2. Jun 7, 2011 at 5:33 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Are you sure you put the coils back on the right side? The Tacoma coils are side specific. Just a thought.
  3. Jun 7, 2011 at 5:36 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    with 65k on your coils, those should be okay
  4. Jun 7, 2011 at 5:45 PM
    skrich72
    San Jose, CA
    '06 PreRunner
    I had a shop do the lift for me, as I had the 1.5" AAL's installed as well. The difference between the right and left side is ~0.5", will swap the coils to see if that makes a difference. Thanks
  5. Jun 7, 2011 at 5:47 PM
    TexasTacoma37
    Take a picture as well like vacountryboy said. That way we can tell if everything is seated properly.
  6. Jun 7, 2011 at 5:48 PM
    ColtsTRD
    Scott
    AZ
    x2...and if your gonna buy new coils just save your loot and get some OME 885s with new UCAs...they'll be fine at 2" for now :cool:
    Just my .02
  7. Jun 7, 2011 at 6:12 PM
    skrich72
    San Jose, CA
    '06 PreRunner
    pics ... 5100's @ 2.5" + 1.5" AAL , rear is 1.75" higher
  8. Jun 7, 2011 at 6:15 PM
    TexasTacoma37
    Hmmm are you SURE they set them at 2.5" instead of 1.75"?
  9. Jun 7, 2011 at 6:22 PM
    skrich72
    San Jose, CA
    '06 PreRunner
    I will get under there a bit later and take some pics. I counted 3 notches (from bottom to top) w/o the clip so I assumed the clip was on the 4th.
  10. Jun 7, 2011 at 6:23 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    there at 1.75
  11. Jun 7, 2011 at 6:24 PM
    Largefarva
    Largefarva Well-Known Member
    Fox Lake, IL
    '08 Double Cab TRD Off Road 4x4
    That's what I was thinking....mine are set at 1.75" and I got right at 2" of lift in the front.
    Can't tell from the pics the OP posted a couple posts up exactly where they're set at. Maybe try to get a close up pic?
  12. Jun 7, 2011 at 7:05 PM
    skrich72
    San Jose, CA
    '06 PreRunner
    Looks like they are on the top setting
  13. Jun 7, 2011 at 7:48 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    So if the stock springs are 886, why do people change them AND change the setting on the shock?
  14. Jun 7, 2011 at 10:06 PM
    skrich72
    San Jose, CA
    '06 PreRunner
    Assuming this is the highest I can go with the 5100's , what are my options? I don't want to break the bank, but I do want a level truck. I've read good things and bad about Toytec's ultimate lift ... but it would give the adjustment if this turns out to be bad coils. Any thoughts?
  15. Jun 8, 2011 at 7:56 AM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    skirch, you mentioned that you now have the driver side lean too. Does this mean you gained the 2" on the drivers side, and have the expected 2.5" on the passenger side? This is the way mine was when I installed 5100's. I got only 2" on the driver side. I then, however, installed the toytec top plate spacer ($20) which gave me roughly 1/2" on the drivers side. I'm level now @ 2.5 on each side.
  16. Jun 8, 2011 at 12:58 PM
    skrich72
    San Jose, CA
    '06 PreRunner
    After another measurement, the passenger side is 1/4" higher than the driver's side. So, I'm not sure if that's really a lean or not? Neither side is at the specified 2.5" height. Tires are the stock 265/70/16
    Here are some pics before and after the lift
  17. Jun 8, 2011 at 3:25 PM
    WaGood24
    WaGood24 Well-Known Member
    Michael
    Dayton, OH
    2010 Double Cab PreRunner TRD Sport
    Extang Full Tilt tonneau, VX Series Exhaust, Nitto Terra Grapplers, Stainless Nerf Bars, Bilstein 5100s all 4 corners, rear-leaf TSB
    I have a noob question... where do you measure the front and back to see what your "lift" is? I'm still stock right now but I've heard that Tacomas can very. I'd like to know if my back end is higher than the front and if so how much higher.
  18. Jun 8, 2011 at 3:32 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    You can measure from either the center, top or bottom of the rim to the fender. You can even measure from ground to fender if you have the same size tire after the lift.
  19. Jun 9, 2011 at 6:07 AM
    WaGood24
    Michael
    Dayton, OH
    Ok that's what I was thinking, but wasn't sure. Thanks.
  20. Jun 9, 2011 at 6:13 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    There's a little thing called Toytec 1/4" top plate spacer to cure the well known 1/2" lean up front...........
