5100s @.85” on stock coils experiences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Micbt25, Apr 6, 2020.
Recommend 5100s @.85” on stock coils?
  1. Yes
    84.0%
  2. No
    16.0%
  1. Apr 6, 2020 at 5:46 PM
    Micbt25
    Micbt25 [OP] Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    All,
    I’ve searched 5100 treads/post ad nauseam. I’m debating on purchasing Bilstein 5100s and installing on stock coils at the .85” setting. I have a 2015 TRD Sport Access Cab 4x4 V6 with EZ-990 Helper Spring Kit on the rear, so it sits a bit higher in the back. I’m also running 265/70R17 BFG KOs AT and I don’t plan on going any bigger. I’ve reached out to a handful of members that have this setup and received some great responses. I just wanted to put it out there to see how many 2nd gen owners have this setup and if they’re happy with it. I’d also like to hear about any issues you’ve encountered since installation (Needle bearing, CV, alignment issues etc.). I have no desire to lift the front anymore than this.
    I wouldn’t do any hard 4-wheeling, the only off road activity would be for beach access and trail riding for camping, fishing and hunting.
    Thanks
    little666nicky and TXpro4X4 like this.
  2. Apr 6, 2020 at 6:28 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I had that setup for almost 100k miles w/ heavy duty dakars on the rear. No complaints! Worked very well for what I needed. In fact, I probably should've stuck w/ a more basic setup since what I have now is more than overkill. But wanted to try it out.
    And I'll also throw out there that I have a pair of 1/2" toytec top plate spacers for sale if you need them to help even out the front and back.
  3. Apr 6, 2020 at 6:31 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I have the same other than the tires.
    Cant complain at all.
    Good luck and Remy
    Buy and cry once bro!
  4. Apr 6, 2020 at 6:43 PM
    little666nicky
    little666nicky Member
    Nikoli
    2015 TRD Off Road
    3rd Gen Wheels Dipped Grill Surround
    I vote yes because I also want to do this to my 2015 DCSB Off Road. Interested in seeing how it turns out!
  5. Apr 6, 2020 at 6:47 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Going on 2 years with this setup on front. Very happy with it and no issues.
  6. Apr 6, 2020 at 6:48 PM
    little666nicky
    Nikoli
    2015 TRD Off Road
    What do you have in the back?
    Sig45[QUOTED] likes this.
  7. Apr 6, 2020 at 6:52 PM
    Sig45
    Mark
    Maine
    OME nitrocharger sports with OEM 4 leaf pack (TSB).
  8. Apr 7, 2020 at 5:31 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I wondered about this too (but set at no lift) and from what I took from the bilstein website was the 5100 is not recommended for stock springs. I may have not comprehended correctly or it may just be bilstein not knowing real world experience. But it definitely gave me pause.
  9. Apr 7, 2020 at 5:46 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have had 5100s on .85" setting for 90k miles. No issues, I didn't notice a change in ride, but obviously it was firmer after the lift. I have a 4 cylinder and it raised the front 1" and the truck sits level with both the OE springs and the recall replacements.
    Sig45 likes this.
  10. Apr 7, 2020 at 5:52 AM
    Sig45
    Mark
    Maine
    Same here - raised the front about 1" and leveled it out nicely while maintaining a slight rake.
  11. Apr 7, 2020 at 5:58 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    They are designed to work with stock springs....I have had them on my truck for a few years now.set at 1.75"
    hmsailor likes this.
  12. Apr 7, 2020 at 6:52 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    That was the first lift I had on my truck,I went ahead and removed the sway bar as well. Loved it,rode great and without the sway bar is was a softer ride. Go for it!
    Micbt25[OP] likes this.
  13. Apr 7, 2020 at 7:47 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Do you have any take off shudder or vibration, before or after the helper kit in the back?
  14. Apr 7, 2020 at 8:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I rock stock TRD OR coils (the progressive wound ones) at 1.75in setting and LOVE them. The extra stiffness gets rid of the boat like ride of the truck stock. At the .85 setting it would be less stiff and closer to stock, id have ZERO problem with them at that setting too.
  15. Apr 7, 2020 at 8:41 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    X2.
    I had them @ .85 on stock Offroad coils for about 60k miles, and the ride was great.
    I now have a newer set of 5100's on a newer set of Offroad coils, set @ 1.75", and agree with the above statement.
  16. Apr 7, 2020 at 8:55 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    With the stock coils I felt the Bilsteins were highly under sprung as stock coils are only 540lbs. Not an issue really if you're looking for a small lift but I noticed that rebound was a bit softer than I prefer.
    If you're trying to go 2"+ I would recommend Bilstein pro lift springs or ome (885 excluded as they are heavy and require a nitrochargers or similar progressive shock) , the springs do the lifting and the 620lb 2.5" spring rate pairs well with the heavier than stock valving of the 5100.
    But as I like to say, it's all personal preference and if it works for you then that should be sufficient for your setup and your taste.
    Micbt25[OP] and little666nicky like this.
  17. Apr 7, 2020 at 9:48 AM
    bordinco90
    bordinco90 Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    I've had my 5100s set at .85 for about 60k miles. No issues at all. It gives my truck a nice aggressive stance. My avatar pic is how it sits.
    Micbt25[OP] and will.i.was like this.
  18. Apr 7, 2020 at 10:28 AM
    Thgr8alex
    Thgr8alex Well-Known Member
    Alex
    Texas
    2012 Tacoma DC TRD Offroad
    Headstrong sells a 2" and a 2.5" coil designed specifically for the bilstein 5100s. I just recently installed the 2.5 and couldn't be happier. Considering it's only an extra 150-200 bucks on top of the shocks, it was a no brainer for me. Doesnt exactly help OP's situation or maybe it does. But figured I'd throw this in there.
  19. Apr 7, 2020 at 11:28 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I just did this like a month ago. All stock suspension except for 5100's on all 4 corners. Had the struts set to .85". It almost levels the truck out but still has an ever so small rake which I prefer. Ride quality is fantastic, hard to compare to stock since I think my stock shocks/struts were well worn, so for me it's a vast improvement. So far I have not experienced any negative effects.
    I should also note the picture in my signature is outdated and I run 265/75/16's.
  20. Apr 7, 2020 at 12:05 PM
    Micbt25
    TM
    No shutter or vibration. I bought it used and it already had the Hellwigs on there. It comes in handy during hunting season when I pick up about 1200 pounds of corn and rides great with that amount of weight.
