5100's @.85" or 5100's @ 0" & Eibach Coils??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cverneau, Dec 17, 2012.
  1. Dec 17, 2012 at 6:27 AM
    cverneau
    cverneau [OP] Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I've been here a while and read all of the threads with regards to leveling the front. I'm just looking for opinions as I still can't decide which way to go - I've got a stock 2011 AC 4x4 4 cyl. automatic.
    5100's set at 0.85 with stock coils = 0.85" lift
    or
    5100's set at 0 with Eibach coils = 1.6" lift
    Are 5100's set at 0 with OME 883'S OR 884'S also an option, and if so, what height would they give??
    I did have the rear TSB done about a year ago.
    Here's where I can't decide - I do sometimes use the truck as a truck. I do load it up at Home Depot and haul firewood a few times a year. I like the stance now with the ass end up (a little too much, though) due to it just about leveling out when it's loaded, however I don't mind the front end being higher when hauling as it's only done a few times a year.
    This is my daily driver and I do not off-road.
    Will the eibach's settle somewhat from the original 1.6" of lift??
    Does pre-loading the stock coils to 0.85 give a fairly harsh ride??
    I DO NOT want to level the truck. I would like to get close to level, but I do want to keep the ass end higher than the front.
    So....how is the ride using stock springs at 0.85 compared to Eibach at 0?? OME 883'S or 884's??
    Some opinions and pictures would be great...
  2. Dec 17, 2012 at 6:33 AM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    I was in your same position a little while ago. I went with Eibach's and the 5100's set at zero. Very happy I didn't go with anything less. With the TSB in the rear my rear now sits maybe a hair less than 1/2" higher than my front. Looks almost level. Check my build page by clicking my sig below. Otherwise here are a couple pics...
    The ride is more solid or firm, but I wouldn't really say it is stiff at all. Couldn't be happier really. Let me know if you have any other specific questions about it.
  3. Dec 17, 2012 at 6:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How much lift are you actually trying to get?
    Since you have a 4 cylinder, the amount of lift and the end result of the lift will be different. With Eibach coils, the 1.6" of lift was on a V6 double cab 4x4, you will get more lift than that. I would avoid Eibach coils on a 4 banger unless you like a rough ride. They are a stiff coil, even on the V6 (I have them myself).
    You certainly can use OME 883 or 884 coils. On a V6, they give you about 1.5 and 2" of lift respectively, on a 4 cylinder, add a little more. I'm not sure how much additional lift you'll get with the lighter front end, maybe someone with that lift will chime in.
    With 5100's set at .85, the ride will firm up slightly but it will not be bad at all. If you start preloading up to 2.5", that's when you'll start noticing a rough ride and even some people say it's not bad. I would caution you with preloading TRD Off Road coils, they are progressive and get stiff in a hurry when preloaded. The SR5 and TRD Sport coils are linear and take the preloading better.
  4. Dec 17, 2012 at 6:41 AM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Pugga's right, with your set up (4 cyl access) I would expect a little more height in the front than me. Doubt you would have much rake if any with the Eibach's. My only issue with the 0.85 lift was whether or not I would regret not having lifted it more once I went that route.
  5. Dec 17, 2012 at 6:45 AM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    SUB'D
    Looking for the same set up with a very good, close to stock ride.
  6. Dec 17, 2012 at 6:50 AM
    cverneau
    Craig
    Cheshire, CT.
    With a 4x4 base model, what coils do I have - linear or progressive??
    I notice yours is a double cab, where mine's an AC. I have to assume yours is a heavier front end to compress more.
  7. Dec 17, 2012 at 6:50 AM
    Pugga
    Massachusetts
    You have linear coils. Only the TRD Off Road has the progressive coils.
  8. Dec 17, 2012 at 6:56 AM
    cverneau
    Craig
    Cheshire, CT.
    I've been leaning towards compressing the stock to the 0.85 setting as it would give a little bit of lift while retaining the ass-high look when hauling stuff. Add to that the additional benefit of minimal messing with the CV angles, and this seems better in the long run. I'm not looking for any specific height, I just want to make it so the ass doesn't look totally jacked as it has since the TSB was done.
  9. Dec 17, 2012 at 7:05 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Mine is set at .85 with the Eibach coils and still sits a little ass high with the TSB add a leaf. Mine is a double cab so it is heavier and the rear had settled a little over time. I have had the lift on just over a year.
  10. Dec 17, 2012 at 7:07 AM
    cverneau
    Craig
    Cheshire, CT.
    I also just realized I wouldn't need the driver side spacer for the lean by compressing the stock coils (as long as I don't mix them up when installing). I think this setup with the addition of 265/75R16 tires (as opposed to the 245's currently on it) would be a decent stance.
    I'll wait and see what others have to say here....
  11. Dec 17, 2012 at 7:19 AM
    jrzyshore
    Scott
    SNJ
    The shock is adjustable not the spring so you would still need the spacer on the driver side for the lean. Unless you go with an adjustable coil over then you would adjust the top of the spring with a spanner wrench.
  12. Dec 17, 2012 at 7:21 AM
    cverneau
    Craig
    Cheshire, CT.
    I thought the stock springs were different lengths (driver side longer than passenger) to make up for this already?? At least that's what I've read on her before...
  13. Dec 17, 2012 at 7:21 AM
    Pugga
    Massachusetts
    He was correct the way he stated it, you don't need the lean spacer when using stock coils...
  14. Dec 17, 2012 at 7:25 AM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Are you saying 2011's don't have factory lean?
  15. Dec 17, 2012 at 7:31 AM
    Pugga
    Massachusetts
    No, all the Tacomas seem to lean a little bit. But, when you use aftermarket coils that aren't side specific, the lean gets exaggerated and you need to use a spacer on the driver's side to compensate. When you preload the stock coils, the coils are still kept on the correct side so at the worst, you'll retain whatever factory lean you had to begin with but it won't get worse as it can with aftermarket coils.
  16. Dec 17, 2012 at 7:35 AM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Gotcha
  17. Dec 17, 2012 at 7:35 AM
    jrzyshore
    Scott
    SNJ
    Yeah I missed the stock part.:eek:
  18. Dec 17, 2012 at 10:25 AM
    Larry
    Larry CARL
    CARL
    I'd go with the 5100's @ .85 and leave the stock coils.
  19. Dec 18, 2012 at 7:00 AM
    cverneau
    Craig
    Cheshire, CT.
    Anyone else gonna chime in??
    Anyone with 883's on 5100's??
    Bueller...Bueller....
  20. Dec 18, 2012 at 7:06 AM
    Pugga
    Massachusetts
    I would tend to agree with this if you only want a slight lift, don't plan on lifting the rear and still want a little rake. I think the other options will give you more lift in the front than you're looking for.
