5100's & AAL - about to order, will this work?
Discussion in 'Suspension' started by dexboi, Aug 20, 2010.
  1. Aug 20, 2010 at 2:05 PM
    dexboi
    dexboi [OP] Member
    Boise, ID
    07 Tacoma DC LB Sport
    885 w/5100 @ .85 Extended Length 5100's LR UCA p285/70/17 Nitto Terra Grappler All Pro Expedition Leaf
    I have had my 07 DoubleCab Long Bed Sport 4x4 long enough that it is no longer seeming tall, as it once did when I upgraded to it from my Honda car.
    I have been researching lifts here for awhile and learned alot thanks to everyone here. I am about to make my order, but just have a few more things to sort out. I do not have the TSB Rear Leafs, the truck has 62,000 on it and it doesn't sound like I can get this fixed at this point.
    Here is what I am thinking about ordering:
    • Bilstein 5100 Series Pre Load Adjustable Front shocks(set to 2.5") - order from DSM
    • 2" lift ToyTec Rear Add-A-Leafs (TAC-AL-HA)
    Do I need to get the following with this setup? Or do I just install the front and rears and see how it drives first?
    • Zinc Axle Shims (3 Degree)
    • Driveshaft Carrier Bearing Drop Kit
    • Longer U-Bolts
    Does this setup sound like it will work to you guys? I am looking for a similar stance as Squad314's DCLB. THANKS
  2. Aug 20, 2010 at 2:08 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Probably won't need to extras. If you do you can order them after the lift is installed.
  3. Aug 20, 2010 at 2:30 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I just did the samething. I didn't need any of the extra's. It did take me 3 times to get my alignement right.
    Before: w/ just the AAL
    After:
  4. Aug 20, 2010 at 3:17 PM
    dexboi
    dexboi [OP] Member
    Boise, ID
    Nice, that is good to hear/see it worked out for your rig. Are you happy overall with it now that you got it aligned? Sounds like this should be a go for me.
  5. Aug 21, 2010 at 2:28 PM
    MAXTacoma
    Lexus GS 350
    Yeah, it has a whole new stance, but the ride and handling never changed.
  6. Aug 22, 2010 at 7:16 AM
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
    I would recommend the diff drop kit from Toytec i just did it for a little added security on my CVs i have very slight vibe just for a sec at 5mph or so nothing to bad probably the only one to notice seeing as i know its there
  7. Aug 23, 2010 at 3:38 PM
    dexboi
    dexboi [OP] Member
    Boise, ID
    Ok, I have gotten the 5100's and 2" AAL ordered, thanks. I guess I will just see how it drives before getting any other parts.
  8. Aug 31, 2010 at 10:11 AM
    dexboi
    dexboi [OP] Member
    Boise, ID
    Alright! I was able to install the AAL's on Friday night, and the 5100's on Sat morning. My initial impressions are that the ride feels more like a 4x4, instead of the spongy suspension before. I might need to look into some rear shocks though, as I think they have topped out a few times from some speed bumps @ 40 MPH.
    I took it for alignment Monday. Here are the specs after: Camber=.1, Toe=.04, Caster - (Left= -.3, Right = -.1). I can notice some wandering at high speeds, but I think I will be ok without UCA's.
    I have also noticed a slight vibration, which I can feel on the pedal and almost hear a little bit. It is definitely different feeling and sounding when I hit the gas than it was before the lift. Because of this I have just ordered the OME carrier bearing drop kit. Should I also try the differential drop, if not for the vibes than at least for the CV boots?
    [​IMG][​IMG]
  9. Aug 31, 2010 at 7:08 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    Quick question, will the bilsteins, set at 2.5, cause any UCA damage?
  10. Aug 31, 2010 at 9:02 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    You may have a vibration after the AAL install. Some do... some don't. I wish I would've installed shims at the same time as my AAL install. To me its worth the extra $70ish to do the extras at the same time some you don't have to pay the labor over again to install the shims/u-bolts.
