5100s adjustment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by t33gee, Mar 19, 2010.
  1. Mar 19, 2010 at 5:48 PM
    t33gee
    t33gee [OP] aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    k and n CAI, magnaflow exhaust, NOS
    So my 5100s came in and I have no idea how to adjust the height. I am at work so I can't look it up so I was hoping one of you guys would chime in. Thanks.
  2. Mar 19, 2010 at 5:52 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Just use a small screwdriver to get the c-clip out of the groove then just slide it up or down to where you want it and make sure it seats all the way into the groove you want. The groove closest to the eye is 0", the next one up is 0.85", the next is 1.75", and the highest one that is closest to the piston is 2.5"
  3. Mar 19, 2010 at 5:58 PM
    t33gee
    t33gee [OP] aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    Right on thanks man. Alignment is necessary after instal correct.
  4. Mar 19, 2010 at 6:01 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Yep, whenever you mess with the steering or suspension, you need an alignment.
  5. Mar 19, 2010 at 7:21 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    not trying to thread jack here but with the bilstiens set at 2.5 will you lose ride quality??
  6. Mar 19, 2010 at 7:29 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Yes.
    A spring only compresses so much. When you set the 5100's at anything above 0", you've compressed the coil part of the way before you even set the weight of the vehicle on it. You've lost distance it can compress so it runs out of travel sooner. It also rides harsher. 5100's are good shocks though. Some say it's not too bad.
  7. Mar 19, 2010 at 7:33 PM
    ak47
    Anthony
    Washington
    stock 2nd owner
    thanks didnt think of that. makes since
  8. Mar 19, 2010 at 9:16 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    My 5100s only had three positions. Approx. 0",1", and 2.5".
    Out of the box it came set for 2.5"
  9. Mar 19, 2010 at 9:20 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Yes the 1st Gen only has 3 settings. And true...anything pass 0" will compress the coils lifting the suspension. Alignment is a must and if you set it at 2.5" and can't get alignment back to specs, you may need aftermarket UCA's.
  10. Mar 20, 2010 at 12:12 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    this is more so an issue for 2nd gen's, I have not heard of anyone having trouble getting a 1st gen to align.
  11. Mar 20, 2010 at 12:13 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    the only thing to consider is your using a better shock, with more oil in it, so the shock itself will perform better, and perform for longer before heating up.
    FWIW I really like the ride of my 5100's at 2.5''
  12. Mar 20, 2010 at 7:34 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Yeah, that's what I was alluding to with my last two sentences above.
    Due to improved shock quality, a 5100 at 2.5" may ride better than a stock set up.
    A 5100 at 0" will ride better than a 5100 at 2.5" though, supporting my original point.
  13. Mar 20, 2010 at 7:47 AM
    Scott K
    Scott K Well-Known Member
    Scott
    Coquitlam, BC, Canada
    Amsoil Synthetic ASL 5w30 Oil, Amsoil ATL Fuel Efficient ATF, Amsoil Severe Gear 75w90 in front/rear diffs & transfer case.
    How is the ride quality of the Bilsteins set at 0.85" ? compared to say stock? It's probably not too bad? Any other issues with this setting or just set it up and get the alignment and you're good to go?
  14. Mar 20, 2010 at 7:53 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Mine were at 0" then I raised them to 0.85". I couldn't tell the difference because it was such a small change. Had I jumped two or three levels, I probably would have noticed. I also have aftermarket coils though. It's hard to say how it will compare to stock because there are different stock suspensions from the factory. Not to mention the various states of wear within them. Pretty much at any level you choose, install them, get an alignment, and enjoy. If you go to 2.5" (or higher from a another type of lift), it is recommended but not necessary to get aftermarket upper control arms.
  15. Mar 20, 2010 at 11:37 AM
    t33gee
    t33gee [OP] aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    does anyone have it set at 2.5 with 265 75 r16 tires? could some one give me a measurement from top of tire to bottom of wheel well please.
  16. Mar 20, 2010 at 4:01 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I'll get a measurement in a few mins.
  17. Mar 20, 2010 at 4:02 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    if you don't have a trd, then you'll love the ride, going from whatever the stock shocks are, to a bigger better bilstein will be lovely!
  18. Mar 20, 2010 at 4:03 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    oops, my bad!
  19. Mar 20, 2010 at 5:29 PM
    t33gee
    t33gee [OP] aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    Got one?
  20. Mar 20, 2010 at 8:05 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    6 3/4'' in the front, and 7'' in the back, that's with a sleeping platform and shell.
