5100's & alignment
Discussion in 'Suspension' started by nasty ned, Jun 3, 2009.
  1. Jun 3, 2009 at 4:43 PM
    nasty ned
    nasty ned [OP] Well-Known Member
    mass
    05v6trd access
    nerf bars ventvisor kit nose & windows
    finally ready to order all around 5100's.i recently got an alignment with my new tires and was wondering if i need a new one with new shocks
    thanks
  2. Jun 3, 2009 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you set them at any hieght, other than stock, yes, you will need an alignment again.
  3. Jun 3, 2009 at 5:16 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    what he said ^^^^^
  4. Jun 3, 2009 at 6:51 PM
    nasty ned
    mass
    05v6trd access
    thanks for the get back. iam replacing all 4 shocks cause the oem are pissing a bit.i was told that these would be my best option if not doing a lift and would really improve ride. just a general ? what do most folks do set it at stock or max them out ? i couldn't get tsb done should that matter:pccoffee::mad::confused::confused::wave:
  5. Jun 3, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Most folks seem to level the truck out with them. I think the 1.75" setting does just that.
