5100's and Eibachs at 0 or 0.85
Discussion in 'Suspension' started by rexel, Sep 8, 2012.
  1. Sep 8, 2012 at 7:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes. You'll get 1.6" with 5100's at 0 and around 2.5" with 5100's set at .85.
    x2. That's a short, and generally safe lift. Post up your alignment numbers if you have them. I'm at 1.6" of lift and on stock UCA's. At around 2" of lift and over is when you should start considering new UCA's. There is no need to replace the lower control arm unless you're going long travel or really pushing the truck very hard. Even with a 3" lift, the stock LCA's are fine and generally not replaced. If you like the ride, no need to replace the coils.
  2. Sep 8, 2012 at 7:09 PM
    Rizzy
    Rizzy Well-Known Member
    Jeff
    Las Vegas
    "Midnight Taco"
    Bilstein 5100's up front, black bull bar, black tube steps.
    Good, I'm feeling better about it then. I'll still post the numbers and maybe try and get a picture of the front end on level ground and see what you guys think. When I first installed them I set it at 2.5 but didn't like the front end higher than the rear so I took it all apart again and set it at 1.75. Very happy with it now. So 1.75 doesn't mean 1.75" of lift?
    And sorry Rexel for taking over your thread :eek:
  3. Sep 8, 2012 at 7:21 PM
    sinaptic
    sinaptic Well-Known Member
    Twin Cities, MN
    2011 Access Cab V6 4x4
    Fog lights, back-up camera, TRD cat-back exhaust, towing package, int. wiper stalk, Weathertech floor liners, color-matched the front bumper and grille, TSB leaf packs, Front Bilstein 5100's at 0", Eibach/Toytec coils (approx 1.25" front lift - sits almost level), rear Bilstein 5100's.
    Well, that's out then.
    I dunno. :notsure:
    Still curious how you're at 2" though; most people on here seem to get around 1.5" out of these coils, which I'm not too far off from... Meh, just one of those things I guess.
  4. Sep 8, 2012 at 8:27 PM
    rexel
    rexel [OP] Well-Known Member
    No problem....I still can't decide what setting I should set my at when I get them.
  5. Sep 8, 2012 at 11:36 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Just about the pull the trigger on this with the aal from toytec, going to set it at .85 and see how she goes
  6. Sep 8, 2012 at 11:46 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    I had the toytec coil over kit and rode in wolfpack's truck^^^ and his rode WAY smoother than mine did. Same springs, same spring rate, basically same truck.
    His is set at 0, and mine was set around 3" of lift. If you aren't getting new UCA's i'd set them at 0.
  7. Sep 9, 2012 at 11:51 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    ^^^x2
    My ride quality improved significantly after I put in more adjustable ucas. Not in that the ride was smoother, but the truck tracked waaay better and the steering just felt more stable
  8. Sep 9, 2012 at 12:09 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I ran eibachs and .85 5100's for almost two years an it was great.
    BUT
    I just switched to OME 885's 5100's at zero with top plate spacers. I also added Light UCAs...
    And I am much happier. CV angle is barely noticeably steeper. Ride is better. handles better. Full 3 inches. Less rake- with 2 inch AAL.
    Would have gone this route the first time around but I was impatient and didn't want to spring money for new UCAs.
    U should be happy either way tho.
  9. Sep 9, 2012 at 2:12 PM
    Rizzy
    Jeff
    Las Vegas
    "Midnight Taco"
    Can't find the alignment print out. I think I might've thrown it away. I'll just take it back this week and have them check the camber again.
  10. Sep 9, 2012 at 2:44 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    I will tell you, I have the 5100s at 1.75 and the alignment is pretty good and in spec when I checked the printout last year, but after a year of driving I can notice that my 265 BFgoodrich ats are not wearing perfectly. The outer tire is scalloping a bit to the point where you can notice. I bought new rims and swapped the walls inside for now, but have Eibachs and LR UCAs that Im putting on. I wouldnt recommend ever NOT using the UCAs if possible, because spending 400 bucks saves your 1000 dollar tires
  11. Sep 9, 2012 at 3:00 PM
    Pugga
    Massachusetts
    Under 2" of lift, you'll be fine with stock UCA's and any decent alignment shop shouldn't have any problems getting your camber at 0 and a decent caster number.
  12. Sep 9, 2012 at 4:41 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    they did but the tires still wear a tad off over time. 25 000kms after i put them on they started to notice. Maybe its just the truck to begin with, but my tires are not wearing perfectly
  13. Sep 17, 2012 at 8:31 PM
    cdnmtbkr
    cdnmtbkr Active Member
    Allan
    Kamloops, BC
    '01 Taco TRD 4x4 (US model)
    Deck-plate Mod, rear window latch pin replaced, Airaid MIT, Magnaflow Cat-Back (#15811)
    I'm in Canada too (Kamloops)! Just wondering where you purchasing the Eibach springs from? Looked into getting them from a Toyota dealer in Alberta but said that the shipping would be 4-6 weeks! Yikes! Do you have a different source (and maybe cheaper ~ got quote for $204 before shipping and taxes)?
  14. Sep 17, 2012 at 9:24 PM
    Hairy Taco
    North of Hell
    08 TRD
    Toytec out of the U.S. will get them to you much quicker
  15. Sep 18, 2012 at 7:04 AM
    #35
    rexel
    I ordered them from Toytec...had them shipped to a US address and picked them up from there.
  16. Sep 18, 2012 at 7:16 AM
    #36
    Hairy Taco
    North of Hell
    08 TRD
    even better if you travel to the states regularly. Save yourself taxes, brokerage and duty(if they are made outside of N.A.) . I also do this. Unfortunately Kamloops isn't exactly hugging the U.S. border.
  17. Sep 18, 2012 at 7:31 AM
    #37
    rexel
    I'm only about an hour from the boarder but I had gone across to pick up some other stuff....never paid duty, just the taxes at the Canadian boarder. Even after the gas expense I saved alot of money.
  18. Sep 25, 2012 at 1:05 PM
    #38
    cdnmtbkr
    Allan
    Kamloops, BC
    Didn't know you could order from Toytec direct and have it shipped to Canada? Just curious and if you don't mind me asking, how much was shipping for you guys? I'm worried about the tax and duty on it being too high, esp. since these are not compact lil' things that could escape from customs. Also, did you guys just get the coil overs or did you guys go for the ones with the threaded collars, thereby adjusting with a wrench to whatever height you wanted?
  19. Sep 25, 2012 at 1:26 PM
    #39
    maxpower29
    Jordan
    Nova Scotia, Canada
    I got a quote from toytec and it was like 100 bucks for the eibachs and rear leafs. So I said F that
  20. Sep 25, 2012 at 1:32 PM
    #40
    rexel
    Unfortunatley if they ship by UPS or FedEX you'll end up paying brokerage fees to get them across the boarder. You should call Toytec and see if they'll ship them USPS.
