5100s and new HD leafs from General Spring
Discussion in 'Suspension' started by Votavanov, Mar 29, 2015.
  1. Mar 29, 2015 at 9:21 PM
    Votavanov
    Votavanov [OP] New Member
    Josh
    California
    2008 Double Cab 4x4 TRD Off Road
    Howdy all - I have a bone stock '08 TRD 4x4 double cab that I tow a 20' camping trailer with. Last trip out I noticed the leaf springs look like they're about to snap (I'm aware of the recall) so I ordered some heavy duty leafs from General Spring. While I'm at it I figured I'd try and level her out since the new leafs will add 1" - 1 1/2", I'm told. Ordered Billy 5100's all the way around, and some new tophats for the front coils (planning on re-using the stock springs). Anyone have this setup? What should I set the front shocks at? 1 3/4" or 2 1/2"? Will it align? Will I need UCAs? Halp!
  2. Jun 1, 2015 at 6:08 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    subbed. I'm interested in these springs as well since I tow a travel trailer. When hooked, the rear end sags pretty bad. These are the springs I'm considering, http://www.generalspringkc.com/product_p/90-297hd.htm Are these what you're looking at too OP? I didn't realize they would raise the rear up even more. I've already got a decent rake that I like with my stock setup. I'd hate to gain even more and look like a reverse bro lean.
    I know the thread is a few months old, but I'm hoping someone can chime in.
  3. Jun 2, 2015 at 11:59 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    I went with wheelers hd 5 lead pack and 5100 shocks all around. I also bought Ome 884 springs. The rear gained 2" and I got 2" from the 884 springs. The ride is excellent. It's firm but the truck is much more solid. My truck aligned fine on the stock uca's. I plan on getting a 18-21 travel trailer. I e had my bed loaded down with 1100 lbs and it dropped about 1.25".
    JC0352 likes this.
  4. Jun 3, 2015 at 9:49 PM
    nach73
    nach73 Well-Known Member
    Nacho
    Pueblo, CO
    06' Pre-Runner TRD- Off Road
    5100's set @0 with 887 springs and 1.5 AAL. Satoshi Raptor grill, Halo Projector led Spyder headlights and syder taillights, Projector led Halo fog lights by Zack/Taco Nation, LED's everywhere else, Raceline 16x8 Assualt wrapped with Goodyear DuraTracs 285/75/16. Wet Okole seat covers, Paracord headrest handles by Cole/Dessert Dunes, Weather tech floor mats, JVC Arsenal KW-V200BT, 2 10" Kicker shallow mount, Alpine components, Alpine 1000 watt amp, interior is completely Dyna matted
    Rossco
    what setting do you have your Billies set at?
  5. Jun 3, 2015 at 10:57 PM
    Rosscopeeko
    BC
    08 DC LB 4x4 sport
    I have them set at 0. My rake is about 1-1.5".
  6. Jun 3, 2015 at 11:10 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    So not for an 08 , but I did a review of my 04 General HD springs with load measure heights.
    Should come up on the search for general HD
    On the 04 they are perfect !!!
  7. Jun 4, 2015 at 7:53 AM
    JC0352
    JC0352 Well-Known Member
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    This sounds like a great setup! Any chance you have a photo from the side? Does it look like the factory rake, but taller?
  8. Jun 5, 2015 at 8:00 AM
    Rosscopeeko
    BC
    08 DC LB 4x4 sport
    I'll try and get a pic once I'm off work.
    nach73 and JC0352 like this.
  9. Jun 5, 2015 at 8:08 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    General HDs, 5100s all around, and OME 884s up front. About 2" all around. Definitely 2" up front, maybe slightly less in the rear. Handles a load much better than the factory 3-leaf packs. I would not change the ride one bit. Stiff, but not harsh. Handles better than stock and I think the height looks perfect.
    This thread shows some photos with just the new leafs--before I lifted the front:
    https://www.tacomaworld.com/threads/general-90-297hd-4-leaf-packs.357147/
    I was originally going to go with the Wheeler's 5-packs. The Generals showed up new on Craigslist from a shop that bought them for a customer who didn't like the idea of a slight lift, so price won out there.
    I have heard that the Wheeler's HDs are known for squeaking badly. My Generals just started to as well. I think it's just because I have a lot of dirt between the leafs. I sprayed them with a car wash hose and it quieted them a lot. At some point I'll pry them apart and clean them really well. Might pull them off and put complete rubber strips between each leaf. Started to with them on, but it was a pain due to the clips.
  10. Jun 5, 2015 at 8:09 PM
    Rosscopeeko
    BC
    08 DC LB 4x4 sport
    JC0352 likes this.
  11. Jun 7, 2015 at 9:12 PM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Thanks for the pic!
  12. May 28, 2018 at 9:10 AM
    dapesche
    dapesche Member
    2004 DC Tacoma TRD
    n/a
    I did a search but only found your 99 pickup write up.
