5100's and new UCA same time questions
Discussion in 'Suspension' started by REDdawn6, Aug 23, 2013.
  1. Aug 23, 2013 at 7:02 AM
    REDdawn6
    REDdawn6 [OP] Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Hopefully going to tackle my front this weekend. I have a couple questions for you guys.
    I have the Bilstein 5100/Eibach assembled from toyec ($599 one), I have a 1/4 spacer for taco lean and I have a set of LR UCA's.
    If doing both at the same time , does the UCA need to be out back in before dropping shock into place?
    I have the 1/4 spacer for TLean, am I going to have any problems with the studs on the shock being too short?
    Does the spacer go on top of shock under the top mount ? Like a spacer lift ?
    Once everything is back together. Do I tighten a re torque up on jack stands or on ground ?
    Any other ideas or comments would be cool too.
    My friend is supposed to come down and help me , he's a gear head so should be smooth. Thanks , RED
  2. Aug 23, 2013 at 7:07 AM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    I did the exact same set up as you and at the same time. I replaced the coilover (leaving stock UCA in place) and then did the LR UCAs. You will be fine with the 1/4 spacers, the studs are long enough. You can torque everything while on jack stands. You can look at my build thread for pictures.
  3. Aug 23, 2013 at 7:09 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Okay. Very cool man. I will check out your build page.
  4. Aug 23, 2013 at 10:58 AM
    Manwithoutaplan
    ID
    THis install will be better with couple ppl.
    make sure you have these handy
    [​IMG] and
  5. Aug 23, 2013 at 2:54 PM
    oFFtaco
    oFFtaco Well-Known Member
    Aaron
    Hawaii
    The 1/4" spacer is a top plate spacer so don't put it on top of the coil. I have the same setup but pieced mine together and I ran two different spacer sizes.
    1/2" Top plate spacer - DS
    1/4" Top plate spacer - PS
    I went this route bc I wanted a 3" lift. So with the billies set to .85, this setup fixes the lean and gives you the extra 0.5"
  6. Aug 23, 2013 at 4:31 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    ok thanks guys... I have vice grips and punches
  7. Aug 24, 2013 at 8:38 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Another question : I have read that adding caster can help in clearance of tires. The directions say set at +2 for LR UCA. I don't really want to keep messing with shit but this would be nice to know. Ty
  8. Aug 24, 2013 at 8:42 AM
    trdNick
    trdNick Odie
    Texas
    Increased caster adds stability at highway speeds. With 2.5-3 inches of lift you want around 2.8 degrees of caster. Set it to the neutral position (+2) and let the alignment shop take it from there, just be sure to give them the instruction sheet that came with the UCAs
  9. Aug 24, 2013 at 8:46 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Ok. Sounds cool man. Thank you.
