5100's and OME springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk3, Jul 31, 2011.
  1. Jul 31, 2011 at 5:21 PM
    luk3
    luk3 [OP] I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    I have heard that 5100's and OME springs are not recommended... Why not? If you set the 5100's at 0 there shouldn't be an issue right?
  2. Jul 31, 2011 at 5:30 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I'm running 885s and 5100s set at zero...rides great and performs even better :)
  3. Jul 31, 2011 at 5:31 PM
    luk3
    luke
    Isle of Palms, SC
    stanky taco
    how much lift are you getting?
  4. Jul 31, 2011 at 5:32 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    There is no issue with them. people have even been running there 5100s at .85" with the 885s without an issue, even though it says somewhere it isn't recommended.
  5. Jul 31, 2011 at 5:34 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Not recommended by the manufacturers of each because they want you to pair their coil with their strut. They do work together just fine. If you're going for the 886's you should probably get OME's struts but 884's and 885's would be fine, just keep them at the 0 setting. The OME coils are tall and it's not a great idea to preload them. Set them at 0 and order the correct coil length to adjust the lift.
  6. Jul 31, 2011 at 5:36 PM
    moblarkus
    moblarkus Well-Known Member
    Mark
    British Columbia, Canada
    '06 Black Sand Pearl TRD Off-Road
    Satoshi grille, All-pro bumper, Allpro UCA's, Walker Evans coilovers, 10" Lightforce Blitz, PIAA 510's,Magnaflow cat-back, K&N CAI, Revtec rear blocks. TSB leafs, Firestone Ride-Rite air springs, Hopkins Agility brake controller.
    I'd like to know how much lift too. I was thinking 886's and 5100's. I'd like a full 3 1/2"s up front.
  7. Jul 31, 2011 at 5:37 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I'm sitting right at about 3"...I didn't use the little spacers that they offer...I'm just using a 1/4" top plate for the Taco lean
  8. Jul 31, 2011 at 5:38 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    any more than 3" up front, you'll kill your down travel
  9. Jul 31, 2011 at 5:41 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    its about 2.5" without the spacers. i set my 5100s at .85 and its about three inches. ride is awesome. i will probably put the 5100s back down to 0.0" though cause i am a little worried bout my cv angles. they currently at 17 degrees and two of the fins are touching each other on the upper boot.
  10. Jul 31, 2011 at 5:41 PM
    moblarkus
    Mark
    If I run the 886's for the bumper, what should I set the 5100's to?
  11. Jul 31, 2011 at 5:42 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    0.0"
    i believe the 885 and 886s are the same length, just different spring ratings to make up for the heavier weight up front.
  12. Jul 31, 2011 at 5:43 PM
    moblarkus
    Mark
    Can you spec a length when ordering OME"s?
  13. Jul 31, 2011 at 5:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    right.
    Andrew is getting a little less height fro mthe 5100s because he's 4wd. I'm a prerunner and don't have the added weight obviously
  14. Jul 31, 2011 at 5:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    no...there divided up by spring rates
  15. Jul 31, 2011 at 5:45 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    yeah and its bullshit. why do i get punished for being a 4x4!!! shits weak!!
  16. Jul 31, 2011 at 5:47 PM
    moblarkus
    Mark
    Thx for the info. Now to decide on Fox Coilovers, Icons, or see if I can get what I want from the 5100/OME set up.
  17. Jul 31, 2011 at 5:52 PM
    Pugga
    Massachusetts
    885's and 886's are NOT the same length...
    884's are 385 mm at 588 lb/in
    885's are 395 mm at 588 lb/in
    886's are 402 mm at 656 lb/in
  18. Jul 31, 2011 at 6:02 PM
    moblarkus
    Mark
    But they are adjustable?
  19. Jul 31, 2011 at 6:04 PM
    Pugga
    Massachusetts
    Fox and Icon are in a different league than the Bilstein 5100's in my opinion. They're a much better set-up which is why they're double the cost if not more. You should decide what your usage is and set a price point to narrow your search. Icon and Fox is much more high performance and rebuildable.
  20. Jul 31, 2011 at 6:15 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    :laugh:
    there's always some bullshit Monday Detail...didn't you get the memo :laugh:
