5100's and spacers??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jayridinfast, Dec 14, 2010.
  1. Dec 14, 2010 at 4:06 PM
    jayridinfast
    jayridinfast [OP] Active Member
    minot nd
    06 taco eccess cab 4X4 v6..loaded
    20 in redlines wit 33 in mud tarrians<unichip chip>magnaflow exhuast>trd cold air>airraid throttle body spacer>bilstien shocks>billiet grill>SHORT THROW SHIFTER>skyjacker rear leafs>apline navigation wit jl w6
    i was carious if u can get more lift combining 5100 ons high setting with coil spacer to get 5 inch front end lift??
  2. Dec 14, 2010 at 4:08 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    no dont stack lifts..
  3. Dec 14, 2010 at 4:09 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    im pretty sure you cant go higher than 3 without a drop bracket. someone correct me if im wrong
  4. Dec 14, 2010 at 4:31 PM
    jayridinfast
    minot nd
    so i can do it with ucas??
    PRO COMP SUSPENSION LIFT KIT -- Provides 6 in. front and 3.5 in. rear lift; Consists of add-a-leafs, lift blocks, carrier bearing spacers, coil spring spacers, strut spacers, rear ES series shocks, relocation hardware, and other replacement
  5. Dec 14, 2010 at 4:49 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    That procomp is referred to as a drop-bracket lift.
    As mentioned above, don't stack lifts!
  6. Dec 14, 2010 at 4:52 PM
    jayridinfast
    minot nd
    so the conculsion cant do no more than 3 without a drop bracket lift fml well christmas budget for everyone else dropped haha
  7. Dec 14, 2010 at 4:56 PM
    KPT
    09 Prerunner
    Plenty of capable offroad trucks here with only 3". Several guys are running 35's on 3" of lift.
    You know your ground clearance actually decreases with 6" of lift, because of the nature of the drop-bracket lift.
  8. Dec 14, 2010 at 8:42 PM
    Blue
    Dylan
    Sierras
    i say do 3 and stay away from spacers and go with a nice set of Coil overs
  9. Dec 15, 2010 at 1:56 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Dont make the same mistake I did. Dump the spacers and spend the extra money on good coil-overs in the front with a AAL and upgraded shock in the rear and you will be set.
  10. Dec 15, 2010 at 4:43 PM
    jayridinfast
    minot nd
    do a set of like king coilovers or icons make a big performance diffence over the billies i got now??
