5100's and Wheeler's 1.5" AAL Installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Moose, Mar 25, 2010.
  1. Mar 25, 2010 at 3:44 PM
    05Moose
    05Moose [OP] Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Here's the final product (along with some measurements for those interested).
    For those not aware, I got the front diff vibe when I installed and went to the 1.75 setting last week. At 88K miles, I'm way out of my warranty. So to deal with it, I had to do some trial and error stuff.
    I lowered it down to the .85 setting today. I can still hear the grinding when it's cold, but not as much after driving on the freeway. After driving awhile, it becomes more of a buzz type vibration in the gas and brake pedals...plus a mild mud tire tread-type sound...at the .85 setting. At 1.75, it was horrible! Although I loved how well it handled the bigger bumps at 1.75, and I liked the extra height.
    Since I still had the vibe at .85, I then thought maybe I would try it at the 0 setting to see if it went away completely. After taking one apart and then measuring it compared to the original OEM shock (why I didn't just do this when I went to the .85 setting, I don't know). Anyway, in measuring the two it appears that the lengths and settings are almost identical at the .85 setting. So maybe this is all a result of a stiffer shock (my OEM shocks were shot) or maybe it was happening before I did any of this and just didn't notice it because I wasn't looking for it???
    Anyway, I'm leaving it at the .85 setting and will just ignore the sound for now. Before I show the pics at both .85 and 1.75, I thought I would share some measurements. I measured from ground up to the bottom of the fender directly over the wheel center. Remember, I added the Wheeler's 1.5" AAL in the back too, and I have the tonneau and 2 60-pound bags of sand back there:
    And now for the pics...
    First the 1.75 trial:
    And the final at .85:
    Honestly, I can't tell the difference looking at the pictures!
  2. Mar 25, 2010 at 3:53 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I can see about 9/10s of an inch difference.
    Just kidding. looks good man.
  3. Mar 25, 2010 at 6:00 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Ok , i am preatty much the same as you
    TSB in the rear, 5100s set at .85
    Im not understanding your noise, grinding??
    Did you get a alignment after installing the 5100s?
  4. Mar 26, 2010 at 7:49 AM
    05Moose
    Jim
    No, the outer bearing on the driver's side in the front differential is failing on a lot of our trucks (I've read estimates of about 10 percent of those lifting their trucks have the bad bearing...so who knows how many have a bad bearing that haven't lifted their trucks). You won't hear it until you raise the truck up to a certain height (I hear it at .85 and it's horrible at 1.75). At stock, you don't hear it. Switching to 4wd eliminates the grinding. You can read through this whole thread (and I'm sure there's some here on TW too), but cj99si was the first to have the dealership diagnose it and replace his front differential (you can jump to page 19, post 279). In fact, he's had his front diff replaced twice under warranty for the same bearing failure. Others have the same problem with less than 30K miles on their trucks!
    http://www.toyotanation.com/forum/showthread.php?t=220615
  5. Mar 26, 2010 at 10:59 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    O well still is a great lookin truck!
  6. Mar 26, 2010 at 5:34 PM
    05Moose
    Jim
    I will update that there is definitely a handling/ride difference between .85 and 1.75. Depends on what you're looking for as to which setting you should go with. While the 1.75 setting is a "cushier" ride over large and small bumps, it feels a little more loose in the handling. The .85 setting will give you more of a stock handling feel (sticks to the road better for cornering and such) but you feel the bumps more like you do with the stock suspension.
  7. Mar 26, 2010 at 5:43 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Thanks for posting the pics. I've been wondering what my DC LB will look like with 5100's at 1.75 and 1.5 aal, and now I know!
    Are you going to get the bearing/differential replaced?
  8. Mar 26, 2010 at 7:22 PM
    05Moose
    Jim
    Not until I have to. I'm not under any warranty, and I think the cost when done under warranty was $1,700 (just the part alone). The dealerships replace it that way because it's cheaper for them than spending the time to take it apart. I'll just see how long it lasts. Eventually I might have to tear it apart, but it's kinda scary when looking at the detailed directions.:eek: Maybe I'll enlist the help of my dad (retired toyota mechanic), but he's getting up there in age.
  9. Mar 27, 2010 at 12:12 PM
    69z28
    69z28 Hell bent for leather
    Kenmore, Washington State
    2006 D-Cab Sport 4X4
    Just had 5100's installed with no rear end tsb or AAL's at the 1.75 setting.
    I have a double cab( 06 ) 4x4 sport, Long bed also. Check out my recent
    post in the recent threads area for pictures ( by 69z28 )
  10. Mar 27, 2010 at 12:29 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Thanks for taking the time to share your measurements...what size are your tires and wheels?
  11. Mar 27, 2010 at 12:39 PM
    69z28
    265/70/17 Terra Grapplers on 17x9 Liquid metal wheels
  12. Mar 27, 2010 at 2:18 PM
    05Moose
    Jim
    While I'm running 265/70-16 for now (hope to go to 265/75 this fall and correct the stock speedo error), the advantage of posting the measurements with the difference columns was that it won't matter what size tires you have. Use the difference column to add to what yours currently measures at to get an idea of what each setting will mean for you.
  13. Mar 27, 2010 at 6:34 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    i did not know it was a comon thing i just had my front diff replaced under waranty at 27000 miles for a bad bearing.
  14. Apr 14, 2010 at 9:25 PM
    05Moose
    Jim
    UPDATE:
    I took 08TRDOFFROAD's advice and installed the differential drop yesterday. Setting the 5100's to .85 raised the front 1 inch and installing the diff drop essentially placed the front diff at the same angles it was with the stock shocks. After driving it all day today and testing it out, no more vibe. Can't hear it, can't feel it.
    So a big Thanks goes out to ya! You da man![​IMG]
    Too bad I could feel it at .85 because I would have loved to put them at 1.75 for the ride quality and then have the drop to put it into the same angles as the .85. But that would just bring back the vibe.
  15. Apr 15, 2010 at 4:15 AM
    rsincavage85
    rsincavage85 Well-Known Member
    Rick
    Plains Twp. Pa.
    Super White SR5
    05Moose I noticed you describe the same lift set up I was looking at getting, from the sounds of it seems to be good. Your truck looks good and now I have an idea of what mine would look like. You have the timbrens and how are they? I only ask because I don't have the TSB done to my truck. I am still have to order mine froom Wheelers probably do that tomorrow and still need to measure where the ruck sits stock. Thanks
  16. Apr 15, 2010 at 9:08 AM
    05Moose
    Jim
    Timbrens were a life-saver before the AAL. Worked great when loading up the back with firewood and made the ride much smoother when loaded. But if you don't have an extra leaf, the timbrens will touch the frame more often. I think that makes for a slightly bouncier ride...or maybe it was all due to my worn-out shocks. I just can't believe the difference in the ride from before!
    With the AAL, the timbrens probably will never be used. I hauled a couple of loads of gravel last week (1/2 yard each time) and the timbrens weren't even being used because the AAL helped out so much. Rear leafs were pretty much flat all the time, now they're shaped like they should be.
  17. Apr 15, 2010 at 11:53 AM
    rsincavage85
    Rick
    Plains Twp. Pa.
    Super White SR5
    Thanks, I was undecided on the timbrens because I plan on using the truck to haul stuff just not all the time and the AAL sounds like all i need. Now to just order what I need.
  18. Apr 15, 2010 at 1:32 PM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    .90" at 30feet away looks like a gnat :)
  19. Apr 15, 2010 at 3:56 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    Buy a diff drop. $20
