5100s as a leveling kit.
Discussion in 'Suspension' started by RtacomaN, Jul 27, 2012.
  1. Jul 27, 2012 at 11:11 AM
    RtacomaN
    RtacomaN [OP] Well-Known Member
    Taylor
    Colorado
    Would just ordering 5100s up front on stock coils and stock rear act as a leveling kit set at 1.75?
    Would I run into problems doing this?
  2. Jul 27, 2012 at 11:13 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Dude your in college; you should be better at research than this. Look at the suggested threads at the bottom of the page. Just make sure that you are looking at 1st gen stuff...
  3. Jul 27, 2012 at 11:16 AM
    RtacomaN
    Taylor
    Colorado
    Thanks for the flame
    . Hard to do when search function doesn't work well on iPhone at work.
  4. Jul 27, 2012 at 11:18 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I was slightly nose-high with 1.75 up front and stock rear
  5. Jul 27, 2012 at 11:19 AM
    greenrustic
    NY
    In that kind of mood today...search works ok on a phone if you use one of the apps.
  6. Jul 27, 2012 at 11:27 AM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Do it! Thats what im doing, and i just got my 5100's the other day and saw pics, im doing 5100's all around and setting it at 1.75 in the front, the front will still be a 1/4 inch lower than the rear because the stock ride height is 20 inches for the front and 22 for the rear, the rear bilstiens wont change the rear ride height , it will stay at 22 inches and the front, when setting it at 1.75 will be 21.75, a 1/4 inch difference in the front, utilizing the 5100's is the most proper way to do a level on a tacoma
  7. Jul 27, 2012 at 11:33 AM
    kyleTRDtaco12
    Kyle
    New Jersey
    Hope my post helps, and no u wont run into problems , the billys are designed to work.with you oem springs, but the only thing i.was told ud run into a problem.is if u are putting the billys on a trd offroad tacoma, because the trd offroad runs a progressive front coil as opposed to the regular coil spring used on the base, sr5 and trd sport tacos, u want the normal spring when u use the 5100s because the progressive spring with the 5100s affects ride quality .. Hope this helps again
  8. Jul 27, 2012 at 12:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There is no 1.75 setting on the 5100s for 1st gens
  9. Jul 27, 2012 at 12:24 PM
    TexasTacoma37
    Ah, first gen. OP you should really put the year in your truck description under your name.
    The settings for first gens are 0, 1, and 2.5"
  10. Jul 27, 2012 at 12:31 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Ohhh snapp, 1st gen lol xP and hey dude, why did your 2nd gen sit high on 1.75?? I dont thin it should have, did u have 5100's all.around?? Or just in the front??
  11. Jul 27, 2012 at 12:39 PM
    TexasTacoma37
    It depends where you measure from. I put a level on the frame and I was nose high, barely.
    You can't measure hub to fender to judge levelness because the rear fenders are cut slightly higher than the fronts IIRC.
  12. Jul 27, 2012 at 12:41 PM
    98tacoma27
    Ben
    Not Beech Creek
    cough1.25"cough
  13. Jul 27, 2012 at 12:51 PM
    TexasTacoma37
  14. Jul 27, 2012 at 12:51 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    But u couldnt tell just buy standing back and looking at it could u?? And did u have the 5100 shocks all around??.front and back??
  15. Jul 27, 2012 at 12:52 PM
    98tacoma27
    Ben
    Not Beech Creek
  16. Jul 27, 2012 at 12:53 PM
    TexasTacoma37
    I could definately tell standing back and looking at it. But I'm picky.
    Many of the "leveled" trucks on here look nose-high to me.
  17. Jul 27, 2012 at 12:53 PM
    RtacomaN
    Taylor
    Colorado
    @ everyone else Thanks for the help guys. Sorry for the confusion on my description it says 99 if you click it. My main question was just rather the rear bilsteins were needed if I was just goin to level and run a 32 inch tire. Thanks for all I you who were helpful.
    @ green, dude just don't flame man it's so much easier to just ignore me haha it takes away from the thread and puts us off topic.
    Sorry for the twitter reply. Again hard to multi quote with such a small screen
  18. Jul 27, 2012 at 12:53 PM
    TexasTacoma37
  19. Jul 27, 2012 at 12:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    Meh, tis only 250 thousandths of an inch. Here here!! :cheers:
  20. Jul 27, 2012 at 12:56 PM
    RtacomaN
    Taylor
    Colorado
    Haha yea I could confirm if I order them lol. Is down south done with 1st gen Billy's? There out of stock, the coupon is running out an I need to order!!
