5100s at 1.75 or 2.5?
Discussion in 'Suspension' started by dgr540, Jul 16, 2010.
  1. Jul 16, 2010 at 8:01 PM
    dgr540
    dgr540 [OP] I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I just got done installing my 1.5 AAL and rear 5100's. Tomorrow I am planning on installing the front 5100's. Not sure if i want to set them at 1.75 or 2.5. I have the TSB and 265/75/16. I dont want to look silly if my tires are to small, and not sure what the ride will be like at 2.5. Maybe some opinions will help me make mind up.
  2. Jul 16, 2010 at 8:03 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    Just do it!!
  3. Jul 16, 2010 at 8:15 PM
    dgr540
    Friendswood, TX
    do you work for NIKE?
  4. Jul 16, 2010 at 8:19 PM
    747 function > form
    1st Gen.
    Pics post-install, at both heights...opinion will follow.
  5. Jul 16, 2010 at 8:27 PM
    dgr540
    Friendswood, TX
    eek that would be a little tough having to redo the coils and everything.
  6. Jul 16, 2010 at 8:32 PM
    747 function > form
    1st Gen.
    QFT, imho you'll be good if you're running m/t or a/t tires [EDIT: as far as looks go (as for ride, I dunno)] . Nonetheless, post pics post-install.:)
  7. Jul 16, 2010 at 8:38 PM
    dgr540
    Friendswood, TX
    I sure will.
  8. Jul 17, 2010 at 10:41 AM
    dgr540
    Friendswood, TX
    I need help fast!!!!! I cant get the bolt on the UCA to come out. I tried the wood and hammer, but nothing to working help!!!
  9. Jul 17, 2010 at 10:49 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    :rofl:
    hahahahha i dont know why but i laughed so hard when i read this!!
  10. Jul 17, 2010 at 11:25 AM
    dgr540
    Friendswood, TX
  11. Jul 17, 2010 at 12:11 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Did you work the spindle nut down where it's flush with the bolt? Then just tap the bottom of it. Not too much though. The nut will give you more surface area so you won't damage the bolt. Try it out. Good luck.
  12. Jul 17, 2010 at 12:23 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Are you talking about the long UCA bolt? Don't you need to bend the inner fender a little bit to Jimmy it out? If your new UCA came with new bolts just hack it off...
  13. Jul 17, 2010 at 1:42 PM
    dgr540
    Friendswood, TX
    Well I got it off with out having to remove the UCA. I am having NTB put the new shocks in the coil because the compressor I rented/ borrowed safty pin wouldn't go over the coil. so $40 to have them do if fine. Just waiting now.
  14. Jul 17, 2010 at 2:10 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I am contemplating this same issue. I heard its hard to align the front sitting at 2.50 if so maybe 1.75 would be best. I dont want alignment issues, the damn tires cost to much. according to my measurements, the back sits at 7 inches and the front around 4. So 2.50 would make since.
  15. Jul 17, 2010 at 6:08 PM
    dgr540
    Friendswood, TX
    Went 1.75 will take pics after alignment.
  16. Jul 18, 2010 at 10:32 AM
    dgr540
    Friendswood, TX
    Here are some pics of final product.
  17. Jul 18, 2010 at 10:39 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    looks good.
  18. Jul 18, 2010 at 10:45 AM
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    what are ur measurements from the center of the hub to the bottom of the fender? looks good btw
  19. Jul 18, 2010 at 10:56 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
  20. Jul 19, 2010 at 7:51 AM
    dgr540
    Friendswood, TX
    Yes i did 1.75". I will have to measure from the hub.
