5100's at 2.5'' and 2'' aal level?
Discussion in 'Suspension' started by xGManx, Dec 22, 2010.
  1. Dec 22, 2010 at 9:41 AM
    xGManx
    xGManx [OP] Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    i just found out i dont qualify for the TSB :(
    i have 5100's at 1.75" in the front and the back is a little low and saggy
    if i adjusted the 5100's to 2.5" and got a 2"aal would it be level?
    i also have 265/70/16 cooper atr's, would the space between the tire and the fender look out of proportion? i know its an opinion question but i dont have an opinion so fill me in
  2. Dec 22, 2010 at 10:19 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Depends on what your measurements are right now from the ground through the hub to the wheel arch. Mine were 35" front, and 37" in the back stock. I added 5100's at 0.85 with the eibach spring up front and got 2.6" of lift. I added a 2" AAL to the back and got 2.25" of lift...now the measurements are 37.6" front, and 39.25" in the rear...looks good with just a little rake to the front. Pics are in my gallery. Keep in mind that the rear arch is approx. 0.5-0.75" higher from the factory as well, so if you end up even front to back, your rear end is actually lower.
  3. Dec 22, 2010 at 10:33 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I wish more people would realize this.
    I like the raked look.
    I just installed 5100's at 2.5 and 2" aal in the rear. Pics can be seen if you search my name.
  4. Dec 26, 2010 at 1:12 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    Depend on if you're using stock springs and 2" AAL your truck will set level .
