5100's at stock height?
Discussion in 'Suspension' started by asus611, Feb 18, 2010.
  1. Feb 18, 2010 at 7:27 AM
    asus611
    asus611 [OP] Well-Known Member
    CA
    03 Double Cab Prerunner
    Hello,
    My 2003 DC Prerunner (non-TRD) has about 95,000 miles on her, and I'm planning on replacing the torn up OEM shccks with 5100's all around. I don't plan on lifting her, or even replacing the OEM wheel/tire setup. Too old for that. HAHA. Just looking for a good handling, semi-civil ride quality. Anyone have feedback on leaving their front 5100s at stock height? Less preload should be a smoother ride correct? The 5100's are cheaper than HD replacements, which is a plus for me, even though they are backordered right now.
  2. Feb 18, 2010 at 8:27 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Hmm never heard of anyone doing this? I would think the 5100's would be good cause they have better valving.
  3. Feb 18, 2010 at 12:58 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    it will ride better than your OEM setup at stock height because it will be more solid and abosorb the bumps better.
  4. Feb 18, 2010 at 1:04 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    It would be great but I don't think you need to spend that much to get a nice stock, no-lift replacement. It certainly doesn't sound like you need to pay extra for heavy duty or height adjustment capability.
  5. Feb 18, 2010 at 2:06 PM
    asus611
    CA
    Yeah, see that's my dilemma. I don't offroad but I tow pretty often and load motorcycles/cement/house stuff etc in it. Lucikly for me I own a truck so it's always being used as a mule by friends, family, etc. I want a stiffer ride for the utility, not for offroading.
    My gut reaction was to get the Bilstein HD's for more "oomf".. but they are actually MORE than the 5100's. And I could get some cheap monroe's or the like for a cheap stock like swap, but I figure since I'm swapping them out, might was well upgrade a little.
  6. Feb 18, 2010 at 2:10 PM
    Brunes
    Brunes abides.
    Rotorhead
    The SPRINGS are responsible for the stiffness of the ride under loading. The shocks help smooth it out.
    The shocks will make it ride a bit nicer- but if you need loading capacity/weight handling. You need to look at new springs.
  7. Feb 18, 2010 at 2:19 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    i've got a set of oem bilstein trd's i took off my tacoma if you want. they've got decent life left in them (were on the truck for 40k miles).
    pm me if you're interested. :)
