5100s at wrong setting
Discussion in 'Suspension' started by bennett, Jan 17, 2012.
  1. Jan 17, 2012 at 3:03 PM
    bennett
    bennett [OP] Well-Known Member
    Bennett
    Georgia
    08 SR5 4X4
    5100s on all 4 corners(Fronts at .85); Eibach Coils; Toytec Diff Drop; Toytec Top Plate Spacers; Toytec AAL; 285/75R16 MTZs
    Hey yall, I've got a 3'' lift with 5100s and eibachs. Been concerned b/c my truck doesn't look level. Well today I got under my truck and felt up under the spring seat of my shocks with a bent paper clip. I couldn't feel a notch so i'm thinkin the guy that did my lift might have set my 5100s at 0 even though i told him to set them at .85. If the shocks were at .85 would i even be able to feel the 0 notch by sticking a paper clip up in the spring seat? What do yall think?
  2. Jan 17, 2012 at 3:05 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver
    need a close pic of the shock body. if its set at .85 there should be 1 ring showing below he spring seat
  3. Jan 17, 2012 at 3:07 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I don't think you'll be able to get to the first notch if you're set at .85. The spring perch comes down pretty far.
  4. Jan 17, 2012 at 3:12 PM
    PAlittlematty
    Beech Creek, PA
    ^^^ possibly correct. i dont remember enough about the ones i had on my '08 to know what they still look like.
  5. Jan 17, 2012 at 3:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    How many notches do you see above the spring perch?
  6. Jan 17, 2012 at 3:14 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    The notches are about 1/2" apart. So it's gonna be tough to tell.
  7. Jan 17, 2012 at 3:14 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    LOL. DERP.:eek:
  8. Jan 17, 2012 at 3:27 PM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    Didn't think about that haha. Went and looked and there's 2 notches i can see above the spring perch. So I guess everythings right. just cant figure out why my truck doesn't sit level
  9. Jan 17, 2012 at 3:32 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Are both sides the same?
  10. Jan 17, 2012 at 3:57 PM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    you mean the same setting on the 5100s?
  11. Jan 17, 2012 at 3:58 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
  12. Jan 17, 2012 at 4:02 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Search for "Taco lean". The driver's side of the truck sits lower. The OEM coil spring is longer on the driver's side to compensate. Eibachs were probably equal length, so the lean is more apparent.
    You can buy a 1/4" trim spacer to compensate. It is sandwiched between the strut top plate and the struct bucket.
    http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-8317
  13. Jan 17, 2012 at 4:04 PM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    I've got the 1/4'' driver side lean spacer though
  14. Jan 17, 2012 at 4:16 PM
    KenLyns
    Belly of the Beast
    So which side is higher? And where are you measuring to?
  15. Jan 17, 2012 at 4:27 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You mean not level front to back maybe ?
  16. Jan 17, 2012 at 4:33 PM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    yeah thats what i meant
  17. Jan 17, 2012 at 4:34 PM
    KPT
    09 Prerunner
    What lift do you have for the rear, the 2" toytec AAL or the 1.5"
  18. Jan 17, 2012 at 5:12 PM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    I have the 2'' toytec aal
  19. Jan 17, 2012 at 5:13 PM
    KPT
    09 Prerunner
    And is the rear 1/2"-3/4" higher than the front?
  20. Jan 17, 2012 at 5:48 PM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    Yeah at least that much. I think I measured about 23'' in front and 24'' rear
