5100's Breakdown:
Discussion in 'Suspension' started by roxspin72, May 28, 2008.
  1. May 28, 2008 at 9:44 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Ok here we go...
    I want a 3"ish lift up front. 1-2" in back. I've got Ready 2.25" level UF now. I want to upgrade to better Bilstiens like the 5100's, but all say dont do it. Well, if 5100's are so good why cant I keep them at stock hight like my TRD Sport shocks and just add the ready lift spacer. And even more, why not add a .85 lift to the 5100's and accomplish an equivelant of 3" lift. Add Diff drop, and some gear change w/royal purple in trans and it seems to be a great investment.
    Am I lost? Top plate spacer dont effect shocks or springs, Just the hieght. And right now all I see effected with 3" is differential angle..
    Need true facts. No hear say... I dont want to spend 2000 on 6" lift but need a 3" lift with ride quality up front and higher rear end.
    Thanks...
  2. May 28, 2008 at 10:32 PM
    carlos chavez
    carlos chavez New Member
    05 PreRunner SR5
    3" Revteck lift All Pro upper control arm 17"Mickey Thompson's wheels 33" BFG KM2
    :confused: Dude u got quite a project.... save up a little more and get 2.5 Fox's or Kings with reservoir thats what I' doing
  3. May 29, 2008 at 6:15 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    whats up Eddie! i love the 5100's, they are a much better shock than the stock billies. from what i've read its recomended that you dont use spacers with the 5100's unless they are at stock height. i dont know exactly why but i would not do it. but if you wanted to keep them at stock height and keep the spacers you have now i say go for it. they will perform better and give you a better ride on and off road. and you should be able to add another small spacer to get up to 3 inches. But like i said, i just wouldnt add spacers and the billies adjusted over stock height. i think that answers your question, if not let me know what other info you're looking for.
  4. May 31, 2008 at 8:57 AM
    roxspin72
    NC
    Oh Yeah!!!
    Hey man thanks...
    This is what I will most likely do:
    Billy 5100's front back = $350ish
    Toytech 3/4" spacer= $65 installed top of my readylift 2.25(if compatible)
    Toytech 1 1/2" rear blocks= $79
    Front Diff drop kit= $29
    So depending on the billys I should have a pretty solid lift all around better suspension than stock TRD, and corrected diff angle, all for about 600ish w/install plus allignment.
    What you all think?
    Looking to get this in July.
  5. Jun 3, 2008 at 2:10 PM
    nd
    Nate
    Greenville, SC
    sounds good! go for it, you will have a really comfortable ride
  6. Jun 3, 2008 at 3:25 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    On ebay,Downsouth Motors caries the 5100 adj.for 269.All 4 otd.Some have offerd less & it was accepted.
  7. Jun 3, 2008 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On reason you dont want to put lift on top of another lift, is that your ball joints will hate you. But in a bad way. If you have a ball joint failure, your whole wheel, brake, spindle,etc. all falls off. It is a No Bueno situationO. :)
  8. Jun 4, 2008 at 12:24 AM
    roxspin72
    NC
    Oh Yeah!!!
    OK thats good stuff to know. The rep at Toy Tech said the OME kit they sell for 229.00 up front will give a full 3" lift. But I really got to research, cause I'd hate for them to sag down to look like what im running now. Anyone running the OME's with stock TRD shocks?
