"5100's Eliminate Rub?"
Discussion in 'Suspension' started by Stormtrooper23, Apr 25, 2012.
  1. Apr 25, 2012 at 9:49 PM
    Stormtrooper23
    Stormtrooper23 [OP] Polar Bear
    BC
    '05 White DC 6-speed 4x4 SR5
    Leer "Legend" Canopy, Peripheral iPod adapter, 13" AntennaX Antenna, Debadged, Pro Comp 7089 w/ Goodyear Duratracs 265/75/16, Colour Matched Satoshi Grille, Sleeved Fog Lights
    Just looking for some answers on if Bilstein 5100's will help eliminate the small amount of rubbing I'm having. I recently grabbed some Pro Comp 7089's and wrapped them in Pro Comp Xtreme AT 265/75/16. I had to remove the mud flaps(no problem) but am still having a minor rub on the inside part of my fender. I was hoping to avoid any trimming and was wondering if Bilstein 5100 HA @ 1.75 would solve this problem or am I going to have to trim regardless. Any help would be much appreciated.:confused:
  2. Apr 25, 2012 at 10:11 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    All else being equal, you lose a bit of caster when lifting, which can help with tire clearance. If the alignment brings the caster back into spec, you will likely have to trim regardless. Keep in mind the wheel at full compression is at the same place (lower control arm hitting bumpstop) whether you have stock struts or 5100s.
  3. Apr 26, 2012 at 5:26 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Are the Procomp wheels the same backspacing and width as the stock wheels? You can run that size tire on stock wheels and not have any rubbing issues.
  4. Apr 26, 2012 at 6:08 AM
    KenLyns
    Belly of the Beast
